I'm in the process of adding a second 100 Ah lithium battery to my T@B 320 and have a question about the appropriate wire size for the jumper cable connecting the two batteries..
I understand that the parallel connection will result in a system with 200 Ah's of capacity but the connection is between two 100 Ah batteries. Does that mean the most amperage that can flow over the jumper is 100 amps, and that is what I should size the wire to? Or should the jumper be able to handle the total 200 amp current of the dual system? I think this basically this boils down to the question of whether I should use 8 or 4 AWG for the jumper.
The biggest draw will be from an inverter, if you have one. For the battery parallel cables I would match those that go to the inverter. If you don't have an inverter you could go with 4 or 8 AWG wire. If it were me, I would match the large wires that attach to the original battery (0 or 00). Then you have the flexibility of adding an inverter if you don't have one.
Here's a good site for wire gauge vs acceptable current draw.
https://www.powerstream.com/Wire_Size.htm
Brad
Concord, NC
Both batteries are connected the with 10g wire protected by 30A fuses. I too have often wondered why much heavier cables are the convention for dual-battery configurations, even if the total draw will never exceed 30A. I suspect I might be missing something here, but I can't see what.
