EMS vs Surge vs nothing
stevel
Member Posts: 6
Just curious who uses an EMS (Energy Management System) rather than a surge protector. Since I use PayPal quite a bit for purchases I got a $10. off Camping World Figured why not take a look, I'm board. Saw the Progressive EMS which I thought would be a good thing. Their ad Progressive Industries EMS-PT30X 30 Amp EMS with Surge Protection, 18"L
(91)Save $118.47 ( 32% Off ) Sale Price$251.52 Regular Price$369.99 I googled it and found that $251. is the going price everywhere. Now I normally don't buy from Camping World just because of things like this but it made me think who uses an EMS and who uses surge and who uses nothing?
I have a hardwired Hughes Autoformer Power Watchdog. It’s an EMS. I think they’re cheap insurance in the long run considering what can happen if you had a surge. Plus I like seeing how much power I’m pulling and it came in handy when I was working through some issues with my AC and generator (allows you to see watts/amps in real time).I think there are pros and cons of a hardwired vs. plug-in version. Having it hardwired was a win for us since it’s one less thing to have to store and it eliminates theft.2021 400 BD
2020 Tacoma TRD Off-Road1 -
First time with a camper and we got the Progressive Industries EMS-PT30X and a wire bike type lock and feel it is a good insurance too and I like to see the volts / amps from time to time. Not been activated in our first season. If the power pedestal is sloping forwards / a bit loose then a bungee cord can be needed to keep it plugged in as it is a bit of a weight. Or if the pedestal is low then it is sitting in the dirt.2021 T@B 400 BD T@bitha with 2016 Highlander
Juliet and Andy in Massachusetts0 -
As the resident contrarian, I fall in the "nothing" camp. On the occasion when I have a shore power hookup (maybe 1/4 - 1/3rd of the time) I do check the polarity and grounding status of the connection with a simple outlet tester. I don't use many sensitive electronics so I'm okay assuming a bit of risk.
Not that I have anything against the use of an EMS or surge protector, I'm just answering the question as asked. I realize it's probably good insurance, particularly for more risk-averse owners, I've just never summoned the motivation to get one.
Hmmm, this might be a good poll question...2015 T@B Max S (320)
2015 Nissan Frontier SV V6 4x43 -
I actually have been in all three categories. On my old trailer I used nothing but then again I rarely plugged in to power. When we got our T@b 400 I got an inexpensive progressive industries surge protector. Not really doing any research I figured that was fine. But after thinking about how much we spent on this trailer and what can happen if you or someone else plugs your trailer into 240v I figured the EMS was worth it. A surge protector does not help against that issue. I got mine from Home Depot with a gift card I had so it only cost about $200. Cheap insurance in my opinion. I now use the surge protector when plugged in at home and the EMS when traveling.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado1 -
For a few hundred bucks it's worth the peace of mind for us. We did the Progressive Industries hardwired option and it's nice to know we're protected. Like insurance, you don't need it until you do.2
It depends on how you use your trailer. I only plug mine into shore power a couple of times a year and we don’t really have lightning strikes in Northern California, so I just use a surge protector with a circuit tester.
I paid about $226 for my PI EMS-30. Sale price $251 - a $25 coupon.
https://www.campingworld.com/progressive-industries-ems-pt30x-30-amp-ems-with-surge-protection-18l-102484.html
Odessa, Fl.
My thought on having some kind of an EMS is that you have a trailer worth well north of $20k and spending less than 1 percent of that to safeguard all the electrical devices in it seems like a reasonable one-time expense.I wanted the relative ease of use of a hardwired system and went with the PI EMS-LCHW30. Not particularly difficult to install, though in my case it took more time than I expected.2021 T@B 320 S Boondock / 2022 Telluride - Phillies/Eagles/Flyers Country0
@stevel - too often campgrounds don’t always maintain their pedestals. People back over them or run into them and they may never get checked. You never want to risk a “hot skin” situation. In addition, surge protectors do not typically protect against low voltage which impacts your A/C and fine electronics. Go with the EMS.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
I failed to mention this word of caution in my previous post but soon after installing my surge unit I purchased a 30 amp extension cord off eBay. When I went to plug it in I received a "reversed neutral" warning from the Power Watchdog. Turns out the extension cord had been wired backwards. My guess is that it would've just tripped the breaker but I'm not an electrician. Could've been worse.2021 400 BD
2020 Tacoma TRD Off-Road0 -
We went with a hard wired progressive. We camp mostly with hookups.2018 320CS-S
"Just Enough"0 -
4th RV and the first one I have used an EMS. I also installed the hard wired Progressive Industries with the remote display. Although we rarely camp with electrical available to us unless it is hot and we need AC, I installed it for peace of mind and because this is the last RV that I plan to own.
Although I have to admit that I have looked at the Black Series (specifically the HQ19), the only thing our 400 BDL doesn't have is heated tanks. Even if I were to pay someone to add the pads and wiring, it wouldn't be a dent in the price difference between the 2 and most importantly the 400 is as close to perfect as can be for our needs. If my wife even heard me mention a different RV, there would likely be a trip to the hospital involved if I survived the beating.
Brad2020 400 BDL aka "Boonie"
Concord, NC1 -
We installed the hard wired Progressive Dynamics EMS. So far it has activated at two different pedestals, both at state parks. One was at Turtle River in North Dakota and the other in NE Florida (can't remember the name). We use hookups about half of the time we camp.Edit: Meant to type Progressive Industries EMS, not Dynamics...
2019 320 Boondock Edge - Sold Jan 20220 -
If you go with the installed/hardwired unit like the Progressive Ind EMS-HW30C. Consider the location of the remote display carefully. The RED LEDs are very BRIGHT and act as another T@B LED night light. We now have ours installed in the storage compartment, viewable by opening the exterior storage door. This location makes installing it much easier too.
2021 T@B 400 BD / 2020 Ram 1500, Northwest Arkansas0 -
The Hughes Power Watchdog is Bluetooth so you don’t need a display. Some like that. Some don’t.2021 400 BD
We had our dealer install the Hughes Power Watchdog. Glad we have it for the security, and the Bluetooth app is nice, but it does hum noticeably. It is installed near the head of the bed in our BD 400. I’ve gotten used to it, but it bugged me enough at first that I would get up at night and cut off the shore power.
We were worried about that as well but typically we have the fan running at night which drowns it out. And the compressor from the fridge running if it’s a warm night.Binghi said:We had our dealer install the Hughes Power Watchdog. Glad we have it for the security, and the Bluetooth app is nice, but it does hum noticeably. It is installed near the head of the bed in our BD 400. I’ve gotten used to it, but it bugged me enough at first that I would get up at night and cut off the shore power.2021 400 BD
I've been in all 3 camps - we started with nothing and don't plug in often but after finding an open ground at one friends house and some low voltage at a campground with a plug in tester, we bought a Progressive industries EMS (external). It was so big and clunky though that I found I didn't take the time to drag it out. This spring I installed the hardwired version and like it - nothing to do or think about.2021 T@B 320S Boondock - 2018 Toyota 4Runner1
We are in the hardwired camp. We have the Progressive Industries EMS-LCHW30. It has a built-in display, not the brightly lit LED remote display.2019 Tab 320 CSS, 2019 Ranger TV, OH0
Hardwired Hughes Watchdog - I don't plug in much but for all the reasons to use it above. Blowing out the circuit boards of the converter, Alde or AC is enough to pay for this but not the service call or time waiting for repair. Personally I think the risk of a real issue is low but in only 1 1/2 yrs of ownership I've plugged into a few sketchy places and wasn't at all concerned though it hasn't triggered once.
Snohomish WA, 2024 3.6L Grand Cherokee
managed by VE Smart Network0 -
Another reason to use some kind of EMS is when using a generator that runs out of gas. The sputtering and voltage fluctuations could damage sensitive electronics. I’m not sure if most generators have built in power cutoffs below a certain voltage. For the $170 I paid for our EMS it’s really cheap insurance.2021 400 BD
I’ve traveled both ways, with and without in the13 years I’ve owned the teardrop style trailers. With my former 2015 T@B I decided to hardwire in the Progressive Industries unit and was very satisfied and comfortable in knowing my trailer was protected and it did ferret out some shaky park equipment on a few trips out west. I had nuCamp wire in the same unit as part of my 2019 400 build too. I agree with what Sharon said too, when you plug into campground equipment keep in mind that others before you have backed into these sites, the pedestals are hit by campers, grounds and connections are loosened up and breakers are flipped on and off thousands of times over the years, yet these facilities really are not inspected and are seldom maintained unless a major event takes place requiring immediate repair work.
For me it also meant one less apparatus to plug in at the camp site, it provided peace of mind and was a small price to pay while protecting the more expensive investment I was towing behind my truck. I’ve been around electricity most of my adult life, have seen some crazy things happen and am of the opinion that if you can build in a safe guard to protect yourself and your equipment it is probably a very worthy investment. But again, to each his own! 😉Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
I use the progressive EMS-LCHW30. I like that I dont have to remember to bring anything as it is always with the Trailer and it protects all possible electrical issues. It has a Lifetime warranty and is repairable without removing the unit. As for the remote display I installed it just below my plug by my feet with velcro...this way I can remove it and put it near a window so I can see it when I plug to a 30amp pole. And if the light is bugging us i just remove it and leave it under the seat..
2021 T@B320 S - 2013 Ridgeline - Ont. Can
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming WOW! What A RIDE!!” Dr. Hunter S. Thompson
There was a post in one of the FB Tab groups earlier today about a hot skin on a Tab, an EMSbshould prevent that, it would dectect the condition and not power the Tab.2019 T@B 400 Boondock Lite0
This being our first season, I started out using no protection but when we started doing less boondocking then expected, I purchased a Progressive Industries surge protector. On our last trip of the season we had a sketchy breaker that concerned me. I'll be installing a hard wired EMS before we start camping next season for total peace of mind and convenience. I'll probably go with a Progressive Industries EMS but the Watchdog is another option I'm looking at.
2021 T@B 320CSS Boondock - "Chirping Bird"2018 Chevy Colorado - "Dad's Truck"0 -
Did you install a hard wired EMS from Progressive Industries? If so, how did it go? Thanks.Scott
Hardwired Progressive Industries EMS. Worth its weight in gold especially after an electrician wired our home 30 amp outlet for 220 instead of 110. Phew!2017 T@B Max-S, silver & silver, towed by a Titanium Silver 2018 Kia Sorento AWD V-6, Twin Cities MN0
Just wanted to share this article regarding “reflected hot skin”. Apparently an EMS will warn about a hot ground, but it will not disconnect the RV from power, leaving us at risk.https://www.rvtravel.com/rv-electricity-reflected-hot-skin-voltage-update-rvt-1028/
Yes, most ground fault detectors will only show or indicate a hot ground, but will not disconnect the load from the source, except for a GFI, which will trip.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0 -
Thanks, @Sharon_is_SAM, for that important reminder! I enjoyed reading that article & also the reminder that a corroded water heater element can be deadly, as it makes me feel even better about installing a protective anode rod in our glycol tank. I plan to follow the link in that article to do the electrical tests for checking the cable ground & wiring in our T@B.
Also, I was surprised & disappointed to see the recent facebook quote in that article citing a real world example of a "hot skin" situation that also involved faulty campground electrical ground wiring at Pocahontas State Park. Please tell me this is not the same one in our county here in Virginia! (And where we spent our very first night in our T@B over 4 years ago.) I applied to join that group to read more.-Brian in Chester, Virginia
RV: 2018 T@B 320S, >100 mods0
