I have been using a LiFePO4 battery in my 320S BD for some time now (BB 100 Ah). For the past several weeks, the camper has been parked in our driveway with the battery on, but with no devices engaged. While it has not been connected to shore power, the drain has been minimal and the only current draw should have been for things like the monitors and the media display. Periodic checks seemed to indicate that the factory solar was keeping things mostly topped up, but I got lazy and did not monitor things for the past several days.
I was greeted with quite a surprise when I checked the camper this morning however. The first thing that was odd was that I could not get a connection to the SmartShunt. I the looked at the SmartSolar readout, and was surprised to see it say battery voltage was 11.08. A double check with the VOM confirmed the 11.08 voltage reading. When I looked through the SmartSolar history, it showed a min voltage reading of 0.78 yesterday, 071 two days ago and 0.74 three days prior! At four days back, the voltage min was 11.78 but every day further back than that was over 12.65, with most over 13.
While I'm suspicious of those sub 1 volt history readings, there's no doubt that battery has been drained to close to 11 volts. Of course the first question is: Has it been damaged? The next question however is about what the cause of the current drain could be?
Appreciate any thoughts or guidance.
We have a large solar system on another trailer (6 100 ah Battleborns) and 1.4 k solar on the roof. We have a 220 amp alternator on our truck, which if the batteries are seriously depleted cannot withstand the draw from the depleted batteries. We had specialized software installed in the truck to interrupt the initial draw to avoid damaging the truck's electrical system. (Our truck is wired to charge this large battery bank so that we are not required to carry a generator). Don't be surprised if that 1 battery is hungy enough to blow some fuses and be prepared.
Cloudy days provide way less energy than sunny ones do, so with the typical phantom loads over a week the BB could easily be nearly drained.
It is not damaged, that's what the BMS does to prevent damage. You have a 10 year warranty, no worries.
Brad
Concord, NC
I done this before I upgraded to lithium and used a PD9260CV convertor, which is not rated for lithium but has a pendant where I can force the Boost Mode to charge at 14.4 volts for up to 4 hours. It takes 3 if my batteries are nearly discharged. It is important to note that the maximum charge rate for BB is 50% of the battery capacity, so a single BB can only be charged at 50 Amps while 2 can be charged at 100 I am using 60 for the pair and may add 2 more batteries this winter. Still pondering that along with additional solar power.
Hope this helps.
Brad
Concord, NC
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
Also, the percentage remains of the battery charge display, is dependent on how,you set up the monitor in its configuration menus.
managed by VE Smart Network
2025 Ford Ranger
