Hey folks, I researched the site but could not find exactly how to access the bottom of the tank where I have leak. To access the bottom of the tank I see I need to remove the shelf/storage box that spans the back but the slant angle of the tab won't let me pull it up and out.
If I remove the screws holding the tank is there enough hose underneath to allow me to lift it up and repair the connection? But I don't think so. Any help appreciated.
2018 Tab outback 320s.
Tab 320s Boondock
TV: Toyota 4Runner
0 ·
https://tab-rv.vanillacommunity.com/discussion/comment/167199/#Comment_167199
Note, I had to remove 7 screws. Also, it may sound odd, but the easiest way I found to pull it out was by laying on my back. You can't get any leverage to lift it out while on your knees leaning forward & it stresses your back; but laying on your back lets you use your entire body for leverage, while letting your arms do the lifting.
You can see my photos of what it reveals, once removed. And no, there's no excess hose to lift the tank out, so don't even try, as you may break the tank connection ports.
There is a thread somewhere where an owner was repairing his cracked reservoir hose connections, I'll see if I can find it and post it to you.
I've discovered that rv dealers are not very reliable for after-sale repairs so I'm determined to learn how to do it myself.
TV: Toyota 4Runner
Don't hesitate to reach out if I can help!
NOTE: I am not saying you can't find people who care, I am saying that "most will do what is necessary and nothing more".
The attitude typically taken is "it's not mine" when they should approach every thing they do like it belongs to their mother. Part of this attitude is driven from the aspect of how they are compensated which is by the "flat rate hour". Which simply means the more work they get done in a shorter period of time becomes more money in their pocket but also the Dealership or Repair Facility. It has been my experience that people will pay above "flat rate" for a job that is well done with an emphasis on personal care. I spent many years as a Master Technician earlier in my career and proved this time and time again to my co-workers at that time.
Today the problem is further amplified by the shortage of qualified people entering into the skilled labor areas. 4 year college degrees have been pushed so hard that people think the only way to succeed is to have a degree, a Master's Degree, or a PHD. It's a shame, because that is why the majority of Engineers are coming from other countries. The USA has mostly abandoned encouraging skilled labor in pursuit of the 4 year degree dream. Kid's today don't want to physically work or get their hands dirty.
Okay, enough of the rant, everyone get's my point.
Brad
Concord, NC
TV: Toyota 4Runner
TV: Toyota 4Runner
In the case of that one hose that has a union just a few inches away from the reservoir you could separate it at the union and then remove the stubby hose after you get the reservoir out.
Be careful as our tank (2015) became brittle and the tank broke at the hose connections when I tried to reinstall. the factory had installed with a lot of pressure on the connection because the hose was too long. I tried various products to weld it back together, but in the end had to buy a new tank.
You may want to shorten the hose when you reinstall if it is pushing hard on the connection.
2022 Ford F350 Tremor | 2022 Cirrus 620
And to fstop32 (field camera depth of field!), that's a good idea to remove the hose segment further away from the tank and work with pulling off the short hose after removing the tank. I'll attack it tomorrow.
TV: Toyota 4Runner
When you put that back together you might be able to get your hands on a 90 degree elbow which can relieve the pressure put on the tank hose neck going forward. I had to totally rebuild my system and I was fortunate to get some parts that don't come standard on a T@b. If I can find what I did with my leftover parts I'll see if I happen to have a spare one. The pic below is what it looks like. This is from an Alde European catalog so the part number might not be helpful but at least you'll have the description and specs if you choose to pursue it. If you happen to be vacationing in Elkhart IN anytime soon you can drop into the Truma/Alde facility and they will sell it to walk-in customers
Oh, and take a couple of pain killers before you dive into that confined space!!!
TV: Toyota 4Runner
TV: Toyota 4Runner
Alde and Truma join forces in North America
Since Fall 2019 Truma Corp. in Elkhart is representing Alde Systems in North America. Alde began business in 2012 in North America and is a sister company to Truma Gerätetechnik GmbH & Co. KG which established its North America headquarters in Elkhart, IN in 2013.
Truma has integrated Alde into their new headquarters opening in Elkhart, IN in Fall 2019. They combine forces sharing a mutual service network, logistics and warehousing, and sales team to support both OEM and retail customers throughout North America. Being in Elkhart will allow Alde to be closer to their OEM customers where they will continue pre-assembly of their systems and distribution.
TV: Toyota 4Runner
TV: Toyota 4Runner
It seems there were some growing pains post merger (probably compounded by Covid) but hopefully this is a sign that things are running a bit more smoothly.
TV: Toyota 4Runner
"Ask them to email us at service@trumacorp.com’or call us at 855 558-7862"
TV: Toyota 4Runner
TV: Toyota 4Runner
TV: Toyota 4Runner
Your situation looks pretty benign to me, though a pain to get to it. I think other attempts at trying to glue the reservoir have met with little success. I'd definitely go with a new reservoir.
As for corrosion though I'd suggest once or twice a season to check the rubber hose to aluminum convector connections. If the rubber hose there looks like it has a bulge in do a search on "corrosion of alde convectors" to get up to speed. If you catch the problem soon enough it's just a time consuming dismantle, clean & replace project, almost entirely labor.
TV: Toyota 4Runner
Alde was heating hot water but not heating the tab. Discovered that there was no glycol in the expansion tank. Felt wetness on hoses under the tank. I replaced a cracked tank after draining out the remaining fluid via the drain under the tab. Using a cheap hand pump bought on Amazon, it took about 1 1/2 gallons of Century glycol/antifreeze to bring it to mid way between low and high on the tank measure. Must have been some glycol left in the Alde but I'm ok with topping it up. (Later, after unit came up to temperature, the level came up to the max mark. )
Before refilling, I removed hose connections where I saw bulges and cleaned up corroded aluminum with dremel tool fitted with wire brush.
flurry of misc. things done after reading many threads. No idea which if any were effective or needed:
- Connected to city water, ran sink faucet for a few gallons.
- Turned off/on all power to help alde reset
- determined that my 2018 unit has auto-air bleeder.
- Renewed air cushion: opened safety drain valve for 5 seconds or so.
Notes (thanks forum helpers):
- Easiest way to remove back storage section after removing screws: lay on your back as if doing a bench press and lift the unit up and out.
- Easiest way to squeeze hose clamps: use small channel-lock pliers
- Have a helper to help manage the hoses when using the hand pump.
Tools I used:
- a small bit - the type used for Tab screws. Electric screwdriver, a short handdriver for screws in tight spots.
- small channel lock pliers
- hand pump
- dremel tool with brush bit
Testing:
Took a while for the heat to come up to temp. but seems to be working now.
Conclusions:
Alde is a pain in the A%$# to understand and to self-service. Lucky campers who don't want to go to mechanic school will have a service dealer nearby! vent over.
TV: Toyota 4Runner
TV: Toyota 4Runner
