Thanks! I thought the tanks would not be heated by the Alde. So I assume you will not have running water in such low temps. I would also assume that in CS models you would need to make sure the kitchen gets heat. However, I doubt most with a CS model are camping in these temps.Dutch061 said:It will not keep the tanks from freezing, they are below the floor except for the black tank on some models.
Brad
Dalehelman said:If you will be involved in outdoor winter sports. Bringing wet or damp clothes inside will create some serious condensation issues. Requiring more ventilation which means more heat loss. Something to consider.
Yep, what we do with our Escape 17 is mount a curtain rod in the bathroom and turn it into a clothing locker with a somewhat isolated ventilation system. Push clothing back or take if off when we use the toilet, and, of course, we don't use the shower in the winter as we are dry camping.
On the TaB400, the Alde keeps the water lines and black tank from freezing, as they are all inside the cabin area that is being heated. As previously noted, the Gray and Water tanks are under the trailer floor on all models. Some 320s have water lines below the floor also.Does the Alde keep tanks and lines from freezing or do you need to keep these winterized? I doubt we would ever camp in such low temps but would be good to know what is needed just in case.
Da_Birds said:Does the Alde keep tanks and lines from freezing or do you need to keep these winterized? I doubt we would ever camp in such low temps but would be good to know what is needed just in case.
Great, thank you Sharon.Sharon_is_SAM said:If you are plugged in and the “priority” is electric, propane is on, when you turn on the Alde, it will heat with electric. But, if the cabin temperature is a couple of degrees lower than the thermostat setting, the propane will kick on. Propane runs at 5 KW compared to almost 2 KW for shorepower, so the cabin heats faster. After the cabin heats to the thermostat setting, the propane kicks off and electric resumes. Propane will again kick on when the cabin temp drops.
