Has anyone here used a Flojet Macerator Pump to pump the contents of your waste tanks into a home toilet? If so, I have questions! We have a 2018 T@B 400. Where we need to park in our driveway is tight up against a banking, which makes using the slinky hose and a bucket difficult.
How well does it work? I would need to pump about 60-65 feet in distance, and maybe an elevation of 3 feet at the most.
Can it run off a regular car battery? Could I buy one just for that purpose and keep it on a trickle charger when not in use? The battery in my 2018 T@B 400 is not easily accessed.
This could be a game changer for quick weekend trips to local Harvest Host locations! It can be a challenge to find a dump station, and we like to use our facilities if at all possible. If I knew I could easily dump in the toilet at home, I'd never have to worry about it again!
Tampa FL
We rarely overnight where there are services or a dump station, so I bought a Flojet a few months ago. There are less expensive units, but this had the least negative reviews. Works great so far. I was always looking for a place to dump after a stay in a state forest or even a casino/Cracker Barrel parking lot. Now, when we return, I back my 400 into my driveway, run a 25ft. discharge hose from the Flojet into the sewer cleanout in my garage, and it works. Plus, I can take my time, there is no one waiting their turn behind me. Works on 12v- I clip on to my car battery but could use the 12v plug next to the sink. Could also put the discharge hose into the toilet but I got lucky having the cleanout in the garage.
Tampa FL
There is a covered battery junction box next to the battery cover that you can access the positive and negative leads of the battery. Here's an example picture. There is a positive (red) and negative (white) terminal that you can connect a 12V device or switch to.
However, each person has their own idea of the "best set up" and I respect their opinions.
Brad
Concord, NC
Tampa FL
