Outside shower hose modification
I was inspired by AnOldUR and ordered up the needed parts and did this modification this morning. Super happy with this. Now I can store stuff in that space without the hose getting caught up on anything and now I have more flexibility in use with a 12' hose.
  • Bt0325
    Bt0325 Member Posts: 7
    Nice nice job.  Can you please provide the bulkhead and quick disconnect part numbers.
    2021 CS-S, “Skreppa”
    Jeep Wrangler JLU
    3.6L eTorque
    3.25 inch hitch drop
  • elbolillo
    elbolillo Member Posts: 549
    NS6D42008 Valved Panel Mount Hose Barb Coupling Insert 1/2 ID Barb
    NS6D10008 Valved Male Thread Coupling Body 1/2 NPT
    These are very high quality and solid parts.
  • YanniLazarus
    YanniLazarus Member Posts: 366
    Looks like those are from Amazon...
    What about a number for the short connecting hose?
    And will you close up the shower head recess opening?
  • Tabnero
    Tabnero Member Posts: 252
    which part is the one shown in the exterior side of the access box
  • elbolillo
  • Bt0325
    My observation is that the short connecting hose on the interior is the original hose cut to length.  As for the recess opening, I’m thinking of closing it with a piece of better quality styrofoam, using epoxy to securely attach.  Closing this hole reduces the potential for rodent access.
    Jeep Wrangler JLU
    3.6L eTorque
  • AnOldUR
    AnOldUR Member Posts: 1,728
    edited December 2021
    Not sure if I was the first to add the quick disconnect to the outdoor shower location, but covering the hole where the original shower head stored was not a concern. There are no risks (insulation, rodent ...) involved in this setup than where not already present when the access door is open an hose is in use. I did put a small strip of foil tap over the hole to be safe. Bad picture, but you get the idea.
  • AnOldUR
    Heads up to @elbolillo, you may want to put a hose clamp on your inside connection. It is a tight fit over the barbed fitting, but hot water can soften the hose allowing the pressure to push it off.
  • elbolillo
    Yeah, I had two hose clamps the day I was doing the install. One was too big. The other too small. Gonna get that fixed this week.
  • elbolillo
    Picked up the pieces from freshwatersystems.com and eBay. Short connecting hose was my original hose cut to size. And I will probably just put a piece of foil tape over the opening.
