Solar panels on nuCamp TaBs
gulfarea
Member Posts: 524
What solar panels does nuCamp use on 320 and what controller? Thanks Art
2019 TaB 320 S Boondock Edge
Just a heads-up for anyone thinking about ordering the solar upgrade or adding solar to their units, here is some literature from nuCAMP which may answer some questions. Did some additional research and came-up with a Sunflare brochure and a link to an interview explaining the technology. This is extremely promising and is consistent with the reading we've been getting from our trailer.
Per factory brochure:
TAG gets 111 watts 8.5 Amps/Hr
TAB 320 gets 133 watts 10 Amps/Hr
TAB 400 gets 190 watts 15 Amps/Hr
CIRRUS gets 120 watts 17 Amps/Hr
Interview: https://www.renewableenergymagazine.com/interviews/stickon-solar-with-cigs-an-interview-with-20171107
F150 Pulling 2019 T@B400 BDL0 -
I have not seen any real-life robust reviews of these. I hope they live up to expectations. I am having one installed in March.
This is pretty cool...
Am I correct from past discussions (and seat-of-the-pants experience) that this is generally not true of most panels? I.e., even a small amount of shading has a disproportionately large impact on panel output?
Yes, many are wired to essentially stop charging or take a huge hit when shaded.ScottG said:Am I correct from past discussions (and seat-of-the-pants experience) that this is generally not true of most panels? I.e., even a small amount of shading has a disproportionately large impact on panel output?2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
2 -
The CIGS technology has headwind from the industry I guess because it will upset a great deal of infrastructure and undermine many financial models based on the aluminum frame & glass approach. My guess is we will see a combination of the two using the best of both within a few years and that bodes well for new commercial applications. For use in our trailers, I see little downside to the plastic covering approach over CIGS as used by nuCAMP and the panel component is so cost effective, it can be replaced in a few years as the technology changes while using all the existing wiring and wiring making it an easy upgrade .vs. the traditional solar panel. The combined technologies have a theoretical 30% efficiency and recently produced ones hit 21% breaking the ever moving glass ceiling of 20%. All this combines to mean that the nuCAMP approach looks like it will be good for us and if new units 4-years from now hit 30% it means we can upgrade and stay boondocking longer.
https://www.pv-magazine.com/2018/07/21/the-weekend-read-cigs-is-back-back-again/
https://phys.org/news/2018-09-perovskitecigs-tandem-cell-efficiency-percent.html
The Sunflare panels specs show slightly less efficiency than the more traditional panels, so we will have to see how it measures up in real life performance. They claim they perform better at hotter temps and and lower light but no hard data or testing reviews available, yet.
The controller is a Victron. This thread describes a 2021 controller as the MPPT 75-10. In the 400's they apparently have the 75-15.This thread from 2019 describes the various panels. It should be a good start, but some newer info would be good.
The panels used on the 2021 (and probably the 2022) models is a Sunflare:
https://www.sunflarexplor.com/
2021 400 BD
2020 Tacoma TRD Off-Road0 -
My 2022 Tab 320 Boondock stock solar panel is the 3M Ultra-Barrier Solar Film. Spec sheet is attached.
2022 Tab 320 S Boondock towed by 2021 Volvo XC60 from Tucson, AZ0 -
@markbless - this appears to be a special, clear cover to protect a flexible solar panel. It is not the actual panel.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Ah, thank you.2022 Tab 320 S Boondock towed by 2021 Volvo XC60 from Tucson, AZ0
This is the one on my 2021 320 S except the connectors are on the bottom.
https://ok4wd.com/brands/sunflare-solar/sunflare-solar-sunflare-105w-solar-panel-sunflex35-nr-105w-ok
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
Are the panels available with the connectors on the bottom?
2022 T@B 320S Boondock0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 918 Tips & Tricks
