I am doing a mock-up in my garage for a battery Inverter/charger upgrade. I want to get most of the cabling done outside of the TAB 400. I did power it up and it works great.
On paper this should run my Air conditioner for at least 7 hours.
I will now be able to stop at a Walmart in the summer and still be comfortable.
For boondocking I can use a smaller generator and use it less often.
SOK lithium batteries 206Ah each 618Ah total
Victron multiples 3000 12v
I did consider the weight, by my estimate I am adding 40 lbs. There is only 10lbs difference in battery weight and about 5X more usable energy storage. I have looked at the frame and crossmembers I don’t think there will be a problem with structure. Ironically I had my original AC replaced with a Cool-Cat that was relocated from the rear to the front so after the upgrade my weight balance will be closer to when I bought the camper.
I will be very interested to hear back on your experience after you have it set up and using it. I am loaded with 400 Ah of Battleborn in our 2020 TAB 400 BDL after adding 2 more batteries a couple of weeks ago. I am on my first outing since that addition and I am very impressed.
I will be curious to 2 factors mostly.
1. How your actual battery life is using your AC
2. Amount of time to recharge the 618 Ah of batteries.
You mention "being able to use a smaller generator less often" to charge your battery bank. My concern would be that to charge at 120 Amps (if I looked at the correct Victron unit) will push the limits of a smaller generator. However, I realize that this unit has Power Control and Power Assist but I don't believe that will do much for charging beyond limiting the charge current to prevent generator overload. Which essentially means that you may not be able to get 120 Amps charging current while using a smaller generator.
I am using a 60 Amp PD Converter and if I am completely spent, on paper it appears that it will take close to 7 hours, which is still a fraction of the time required with the WFCO and stock AGM batteries (at least on a 2020). I have considered bumping to an 80 Amp charger, but it requires a 20 Amp outlet for power. Some of the reviews I have read with the 80 Amp is people having issues trying to use generators that are in the 2000 Watt range and not able to due to "over current". Since I am using a 3500 Watt generator, that is not so much of a concern for me while camping but it could introduce problems trying to charge at home. As per the specs from PD, this is only supposed to draw 1300 Watts (10.83 Amps) but as mentioned from the reviews it apparently is much higher. Which allegedly PD has stated to some of the people who have reviewed.
Brad
Concord, NC
I am suspecting that the Victron unit will take 15 Amps @120 VAC at least while putting out 120 Amps @ 12 VDC
Brad
Concord, NC
I will update the post when I get the system fully installed and post my findings after running the AC off grid and charging with a generator. I admit that I have not used my Honda 2000 to charge the batteries yet but am assuming if I adjust the multiplus amp draw below the generator amp output the generator will not trip.
I understand that I will have limited charging capability though solar and a 9 amp (110w) DC-DC charger off the tow vehicle 7pin but I plan on adding an additional 30 amp DC-Dc charger and Anderson connector to the tow vehicle to get more charge current from my 240 amp alternator. I attached my wiring diagram, I have limited electrical experience so if anyone sees any mistakes let me know.
1. Is the 9 amp DC to DC converter the Victron model?
PS The picture is of the DC to DC converter we will use for our project.
1. Yes it is the same 9 amp (110w DC to DC converter as you show, I was going to use the 18 amp converter but my 7- pin wiring is 12ga rated for 20 amps and that was to close for me. I plan on adding a 30amp converter wired straight to the alternator soon. The two converters should give me 550 watts to charge the batteries when driving. I will also have some power from solar so after a 8 hour drive I should have close to a full charge.
2. My Batteries and inverter are in the back under the bed and the WCO power center is in front under the small dinette seat. I plan to connect to the 6 ga wires going into the 12v feed from the batteries near the WCO up front.
3. The primary reason for upgrading for me is to not need a RV campground on hot weather days. As long as you don’t want off grid air conditioning without using a generator the Harris 6 volt AGM’s work fine.
4 Is it the Tesla Truck? that would look cool.
If you get solar on your camper I would set the converter to match the solar charger value set by NuCamp for AGM’s
I may eventually add about 30 amps of alternator charging for when I am driving and not using the rigid solar but that is a later update. Granted, I have considered skipping the alternator charging and just attaching the 600w of rigid solar panels to my truck bed rack above my truck tent (until I setup camp and move them to my Jack-it). This way I always have essentially 1000w of power while driving or sitting still which would allow me to keep the air conditioner on while driving down the road without drawing on the batteries. Its always nice when you can pull over to the side of the road and have your own air conditioned private bathroom.
Please let me know how the install of the Multiplus goes and any suggestions you have.
Trailer - 2018 Tab 400 with Solar
TV - 2014 Toyota Tacoma Double Cab with bed rack/truck tent
Adds - Jackit bike rack with tongue rectangular tool box
I am starting the install tomorrow. I did not install a Soft start because the Multiplus is a hybrid inverter. When running on a generator if the amp draw exceeds the generator capability the Multiples will temporarily take energy from the batteries to get over the surge. I also got the Control Panel so I can manually set the current limit on the Multiples an amp below the generator current output and above the CoolCat's 9amp draw after startup. This is all in theory, I have never tried it. I will know more when I am done.
I finished the install, took a full three days. Could do it in half the time now that I have been through it.The air conditioner runs great off the Multiplus. The temperature was 79 here yesterday and I actually used the AC off grid to get the temperature down while I worked in the camper. When I purchased the multiples I gave the supplier the incorrect amp charge settings, they set it up for 40 amps which is ok for one of my SOK batteries, but I have three the setting should have been 120 amps. Now I have to buy a VE.Bus to USB interface ($70) to change the charge setting.
Thanks, If I was younger, I would get some additional training and do installs for a living, there is good money in it. I am retired and it was rough getting into some areas. It will take me a few days to recover.
Danny16 I think you are correct on cooling. Two areas I did poorly is venting and wire routing out of the front panel. Next week I will remake the panel that holds the power cutoff switch. It will include a 50mm 12v fan and a 100-degree thermal switch. There is an exhaust vent in the rear of the enclosure for the previous AGM batteries, that should work for removing the air. I will also move the wires down to the camper floor and route the wires between the panel and floor.
Also you were correct on your concern with weight of this battery/inverter. Once I got in there I noticed the AGM battery box was supported by the side panels and floor. The floor had supporter the AC unit so I new it could support a fair amount of weight but to be safe I mounted the new batteries on 2x2 aluminum angles attached to the side panels and the inverter sits on ¾ plywood also attached to the side panels, the floor is seeing significantly less weight
I did remove the converter from the WFCO. I now charge the batteries with the Multiplus. The power box would be a good place for the 24v to 12v converter since it is a short run to the 12v fuse box.
We like some AC for sleeping and some of the parks we stay at have quiet hours that prohibit generators after 10pm. Eight hours would be great.
Waiting for the next episode...
Bill
Jeff & Amy
