Anyone with a 2021 and up 320/400  know any more about the "Stabilizer Levelers" in the newer trailers?  There was one discussion on them back in March, with a few pictures of the Bal manual for them.
There are a couple of other discussions about the newer "stabilizers", but the "leveling" component is getting lost in the discussions because for years the "stabilizers are not to be used for leveling".  (Unless you have Dale Helman's mod!)
So, for owners of 2021 and up trailers.....are you using your "stabilizer/levelers" for "fine leveling?"  Looking at photos, they are much beefier than the older Bal stabilizers. Here is a manual for them from a different trailer company!
And, a picture from the Bal website.  If someone can get the model number of the jack on your trailer, that would be great.
Regardless of the mounting, I don't see this design as ever being good for full levelling as--unlike a scissors jack--the foot travels through an arc as it is lowered. This would impede further extension of the stabilizer once the foot contacts the ground.
@pthomas745, I agree with your assessment of the mounting points. I raised this concern when Dale Helman first installed his scissors jacks. (I don't think his are actually installed on frame cross-members either.) I still maintain this is a valid concern, but at this point extensive field-testing of the mod has not resulted in any reports of chassis damage. YMMV.
That being said, we don't use these as "leveling jacks" but rather as stabilizers. As @ScottG said, we use ours to fine tune the trailer after it's been roughly leveled. I'm still in the Jed Clampett school of leveling blocks with some 2x6 decking boards so I can usually get it within an inch or so and the stabilizer jacks take up the rest.
2017 F-150
Coeur d'Alene, Idaho
jeannie
Each to his/her own. I'll still level with blocks and fine tune with the stabilizer/leveling jacks.
2017 F-150
Regardless, I still say the capability of the jacks/stabilizers/whatever are a red herring in this debate. The attachment points to the trailer may be the weak link and should be carefully considered.
In addition, the application of dynamic loads (such as you and your besties hosting a dance party in your T@B) is also a consideration. There's a reason why pounding a nail repeatedly will drive it into a block of wood, but simply trying to push it with the head of the hammer will not.
The damage won't likely be quickly noticed. It may take months or even a season or two for this unintended stress on the seams to cause leaks.
There is no new idea to grasp unless Nucamp has recognized the benefit of being able to use them as Levelers and provided adequate support at the mounting location. I really hope that is the case in my 2022.
WilliamA
2017 T@G XL
WilliamA
2017 T@G XL
The bigger issues is people may just take this manual as truth and seriously damage their trailer. The owner can then point to this horrible manual and say “well, this is what you told me to do”. Then Nucamp is on the hook because they created a terrible user manual.
The manual is just a regurgitation of basic how-tos that may or may not apply to your particular trailer. It’s why so many of us flood this forum and FB for help all of the time.
2020 Tacoma TRD Off-Road
https://www.rvtravel.com/why-rv-stabilizer-extension-matters-more-than-you-think-1216/
