2015 T@B s. Continuous red light on analog panel. The only variable is a refilled propane tank. Propane turned on, stove and frig work fine on propane. Alde works on electric, will not work on propane. When on propane, you can hear the Alde kick on, the igniter clicking, then the red light comes on, and Alde shuts down. Thoughts anyone?
jeannie
2015 T@b S Max white with silver trim. 2018 GC Trailhawk.
0 ·
All I can think is maybe a little air got in the lines and took time for enough propane to float it's way back to the Alde. A pretty weak explanation, but it's the best I got... :-/
I've had Alde Propane issues like you describe while on battery with a low battery voltage. Battery was not low enough to trigger (digital panel) low battery voltage alert from Alde however it was still too low/weak for Alde to run.
I connected the 7-Pin to TV, started TV engine, and Alde Propane came on and stayed on
(have since upgraded my battery size)
@Mona, your 2015 would have the analog (slider) controls. Now that I think about it the red light could be an indicator of low voltage. Was it flashing or constant?
This from page 17 of the US Alde 3010 operating manual:
- Disconnect Shore Power.
- Disconnect Battery via cut-off switch if installed or by disconnecting a wire
- Turn-off propane valve.
- Disconnect propane pig-tail from tank.
Let trailer sit like that = = = No Power (everything off) and no propane = = =
for 5 minutes or so.
Now reconnect everything in reverse order of disconnects.
- Propane pig-tail to tank first
- Shore Power last.
Confirm your stove top will burn propane . . . run long enough to clear all air.
Now try the Alde on Propane. With luck this hard reset of all systems might clear some Alde operation bug.
Was it the propane tank regulator just not putting out enough to get to the Alde, since your stove and fridge worked? Or was it something inside the Alde?
2022 Ford F350 Tremor | 2022 Cirrus 620
