Refilling toilet
Newbie question: Will the toilet refill after flushing if connected to city water only or does fresh water tank have to be full & pump on?
  • Dutch061
    Dutch061 Member Posts: 765
    It will fill from either, but you have to hold the valve open for the water to flow. It doesn't refill automatically. Also, as you are aware, you only want to add a little bit of water to the bowl.
    Brad
    2020 400 BDL aka "Boonie"
    Concord, NC
  • CrabTab
    CrabTab Member Posts: 457
    edited December 2021
    @cthruglass Generally, the freshwater tank can be empty and the pump turned off when you are hooked up to city water.
    You don't mention what model/year T@B you have. Perhaps you can add that to your signature file for future posts. It will help the appropriate folks answer specific questions.
    edit: ... And welcome to the forum!
    2019 320 Boondock Edge
     - Sold Jan 2022
    @cthruglass - a hook up to city water supplies all your water needs (including flushing) at the time, so, there is no reason to have/use water from your fresh tank.  Use your fresh water tank and pump to supply all water needs when NOT hooked up to city water.  Welcome to the TaB family!
  • cthruglass
    cthruglass Member Posts: 7
    Hmmm. I’m hooked up to city water but only refills when pump is on. Faucets, tho, work without pump on.
    I have a 2021 TabS Boondock.
    Thank you for ur help.
    Maybe something is different with the toilets in 2021s (aren't these cassette toilets?) but this just doesn't jive with the standard T@B plumbing layout.
    The city water connection and the FW tank/pump combo are just two different supplies to the same distribution lines. Everything should work the same regardless of which supply you are using.
  • cthruglass
    Duh! I just figured out u need battery or shore power on to refill toilet!!
    Thanks to all for ur help.
  • Maple_Geek
    Maple_Geek Member Posts: 217
    Interesting...I'm curious as to why that is. I was under the impression that the toilet (like faucets) are purely mechanical. Which part of the toilet requires power?
    2022 T@B 320S Boondock
    2021 Toyota RAV4 TRD Off Road
    Ottawa, Ontario, Canada
    Instagram: new.t@bventure
    @cthruglass - that’s OK.  We’ve all been there😂
    @ScottG - the 2021 320 cassette toilet has an electronic push button filler.
    Ahhh, that explains it!
  • Denny16
    Denny16 Member Posts: 5,430
    Cassette toilets can also have their own fresh water/(chemical mixed in) flushing tank, so the toilet is not always plumbed to the trailer water supply.  Not sure how nüCamp set the cassette toilet up.  Some are connected to the trailer water supply.
    @Denny16 - I believe that the 320 cassettes is plumbed just like non-cassette toilets - no separate tank.
  • Denny16
    OK, thanks Sharon.  I have seen both types of installs.
