At 4500 altitude, followed instructions for high altitude, restart control panel. System ran overnight., then alert happened.
2020 320 s, boondock. Total trips since new..22, times of use. Previous to this trip, dealer said not necessary to check or change glycol.
Lost and confused.
0 ·
Check your glycol level first. If it is ok, you may have air in the Alde glycol lines.
If air is evacuated, the glycol level will drop in the tank.
The first sign anything was wrong was the carbon monoxide alarm. We checked all systems where we we saw the Red Alert. We were boondocking, no shore power. We had turned it off when we left 3 hours before. We did a factory reset, turned off the propane, red alert was still showing.
Is it SAFE to run the a/c and sleep overnight with the OVERHEAT RED FAIL light blinking?
2025 Ram 1500 “MTFLY”
2025 Tab 360cs (in production) “Honey Pot”
”Honey attracts more flies than vinegar”
Red Overheat Fail : Nucamp RV (freshdesk.com)
2022 Tab 400BD
2021 Jeep Gladiator Rubicon
Redding and Pacific Grove Ca.
Avia and the reset worked. I still have a call in to my RV Dealership because I cannot see any fluid in my glycol level. Not sure whether I need to change or add fluid.
Heat worked fine last year but I did hear some rumbling last season.
Highly recommend adding fluid now even if a flush/change is needed in near future.
Keeping the 'tank' within the fluid min - max level will greatly reduce chance of getting air into the system, making life less complicated when using the Avia now.
