Has anyone put three batteries in place of the two golf cart units in a 2019 TAB 400? I am going to replace the original batteries now that LifePo batteries are cheaper. Here is one I am considering. It is 8.5” tall and 13”L x7”W.
Jeff & Amy
Now in Manistee, MI
Note the two short bits of 2x2 next to the water pipes in the photo above. This is where the battery is installed and the 2x2s giving added required support for the heavy batter/batteries. The floor thst covers this area is a 1/2-inch plywood panel that is only supported at the edges, and the two battery support blocks.
You can put two of these batteries where the original two AGMs are (enclosed in the black box under the right side of the bunk) where the original single 12VDC battery was located, as shown below:
The false floor is installed here over trailer floor covering the plumbing and wires under it, and the 2x2s added, are under the battery area to support the battery’s weight. The rest of the floor area is hollow under it and unsupported until it connects to the Alde compartment divider (see top photo).
The floor area next to the original battery area could be used for a third 100 amp LiPro battery. But, if you want to add two or more batteries here, you will need to pull the false floor up, and add more 2x2 support blocks, then screw the floor area to these blocks to create the required support.
2017 Highlander Limited
Jeff & Amy
Jeff & Amy
Brad
Concord, NC
Jeff & Amy
Minnesota and Arizona
It is cleaned up more since this photo in November 2020, I have replaced the PD9260CV converter shown in the photo with a PD9160ALV, and I have moved the display for the BMV-712 into the cabinetry above the air conditioning controls. I used 4-gauge cables to connect the converter to the battery junction block, which allows me to have a full 60 amps input to charge batteries. We boondock almost exclusively and being able to recharge quickly and easily when necessary is important too.
I have also added a fuse block, relays, wiring, and switches to control the heating pads I installed in January. Still need to write that project up, most difficult part was cutting the insulation that was used to line the inside of the frame.
Brad
Concord, NC
To date I have replaced the factory converter with a Progressive Dynamics unit that is Lithium ready. I installed a Victron DCDC charger in my truck and added 8AWG wiring with a connector on the bumper. I eliminated the 12 volt circuit on the 7 way connector and wired 8 AWG to the junction box on the front of the tab. I also have a Victron BMV.
With the two LifePO batteries installed and charged, I unplugged from shore power. As an acid test, I ran my inside AC/DC fridge, truck fridge, lights, entertainment stuff, the Alde, and my CPAP with humidifier and heated hose.
In 24 hours, I used 80ah of power! I know how to use a lot less so this was a test.
I plugged in to shore power and with my PD converter switched to lithium, it charged at 45 amps. In two hours, the batteries were at 100%.
I think that I will be able to boondock and only need to run my generator for a couple hours every few days. (Unless we are out west getting awesome solar like we did a couple years ago.) If we are moving sites, my truck charges at 15 amps now with the DCDC converter with another 5-10 amps from solar. The batteries should recover a good bit between locations.
I’m happy with the results. I have room for one or two more batteries but I don’t see the need. YMMV
I understand that I could have done a more technically correct job with this. The following items could have been done better.
I used 8ga wire instead of 4ga. ($$$)
I used the truck chassis for the ground instead of running a second wire.
I mounted the DCDC charger in the truck, far from the batteries.
I used the TAB wiring from the junction box back instead of drilling a hole and running new 4ga wires.
Yes, there is voltage drop. The wiring to the junction block from the converter got slightly warm after an hour at 45 amps. But I am cheap, lazy, and have not had a good place to work on these projects in the last few months due to moving.
One thing to note is that the BMS in the batteries just stops charging when the batteries are full. One minute there is current flowing, the next minute there is none. There also doesn’t seem to be a ramp in current like with lead battery charging. As I understand it, the “charger” is actually in the batteries, the external chargers pretty much apply current at a controlled voltage.
Being able to boondock comfortably for several days is great and opens up a lot more Harvest Host, Boondockers Welcome, and Hipcamp opportunities in locations and times when AC is not needed.
Happy Tabbing!
Jeff & Amy
2019 320 Boondock Edge - Sold Jan 2022
Jeff & Amy
Brad
Concord, NC
Jeff & Amy
Its not an issue when we are in the unit as we obviously keep it above freezing.
Jeff & Amy
Charger enabled
This setting Enables or disables the battery charger. It is by default set to "enabled".
This setting can be used when work needs to be carried out on the installation. When this setting is disabled, the batteries will not be charged.
Jeff & Amy
With that said, Battleborn recommends that for storage that all devices are turned off and that any charging is also turned off. So, turn the Perko off and disable the solar charging by turning it off as @pthomas745 said.
Brad
Concord, NC
Jeff & Amy
Here is a photo of battery area on the original TaB400s:
To get the battery out is not an easy task, you need to remove the bed area above the battery, pull the floor framing supports and slide the battery out towards the center area.
