I live in Phoenix, AZ so I'm told that this might have something to do with the window falling out of the top track. It's been suggested the heat has warped it but visually everyone looks fine. It literally bakes here in the Phoenix summer weather so I guess it would depend on the heat tolerance of the window material. I haven't been able to find anything from anyone else on this forum whereby anyone else reported this problem. So far, I tried replacing the end caps after looking at another owner's T@B front window thinking that might be the issue. That's not it. I had a friend help me take the window completely off and we measured and inspected the aluminum rack according to the specs of the pics sent to me from the
Trans Atlantic Products CSR, as well as the lip of the window that fits in that track. Nothing looks warped or damaged, but I have some rubbing off of the finish of the trailer where the window sits when it's closed and when I open the front window, it lifts out of the track on the passenger side. My friend thinks the window is rubbing on the trailer when it's in motion due to the window being loose in the track.
I did a temporary MacGyver fix with a plastic cable casing from Home Depot and it will hold the window in place when I open it, but this is not a permanent fix. It's the same as
this one from Ace Hardware, pic below. I contacted customer service at
Trans Atlantic Products. They were very helpful. From what the CSR told me, I would be able to purchase only the items of the window assembly that need to be replaced versus purchasing a complete new window assembly from the dealership which is about $350 from what I've been told. Anyone having this similar issue? What did you decide was the actual issue? Is it the aluminum track? The window itself? Or what did you come up with?
Scratching from window
Pic of measurements of the track and window from Trans Atlantic CSR
Window falling out of track when opening
A pic of the window and track for reference. This side seems to stay put mostly but it can be lifted out of the track as shown.
We took the window and the aluminum track off to visually inspect and measure. Everything looks fine.
My MacGyver fix that prevents the window from lifting (falling out) when opening, I can remove it when the window is closed as the window has no way of falling out when it's latched closed.
A cross section of the plastic casing I used to hold the window in place
Legrand Cordmate used for temporary MacGyver fix
Reflectix BP24025 24-Inch by 25-Feet Bubble Pack Insulation - Pipe Insulation - Amazon.com
I needed to make it wider for the back window so I used duct tape to tape to parts that I cut that would cover the back window then covered the duct tape with a reflective aluminum tape.
Amazon.com: TYLife Aluminum Foil Tape,2In x 108Ft 5.9 Mil Aluminum Air Duct Repair Tape, High Temp and Heavy Duty Metal Foil Tape for HVAC, Pipe, Sealing & Patching Hot & Cold Air Ducts, Metal Repair, Insulation : Everything Else
Look again after rebooting your pc or phone. It's a cache problem. The pic is there.
@Deb55 good to know; not so good for you though, bummer. You say you replaced the window. So what did you do afterwards to avoid this from happening again? Are you simply leaving the window shades open now? Is that enough to avoid future warping on your replacement?
Here's my plan, subject to change:
I removed the reflectix from inside the front window. Since my window is already warped, I decided not to replace it and have this repeat as it seems to have with @RayJim so instead, I'm planning on making an awning out of reflectix to put over the front window (then the sides after I figure out how to make a good awning for the front) and "measure" the coolness of the window and inside of trailer by doing this.
Since I don't see anything structurally wrong with the window per se, I plan on continuing with my MacGyver fix until I troubleshoot this and know that I can (hopefully) prevent this from happening in the future since this seems it would be a recurring expensive replacement.
In sunny weather, I have found, opening the privacy shade, opening the bottom of the window to its open latch position, and pulling the bug screen down works well. Air temp. is able to equalize on both sides, get some air flow inside the trailer with the top vent partially open, and so far two summers into the new front window, no wrapping, and window still seals when shut. Even if it rains, water will not leak in when window is in the “vent” position.
I just got a price in a new front window from Tom's Camperland, Surprise, AZ.
Window - $425.00
Shipping - $40
Tax - $36.13
Total = $501.13
Yikes! That's without installation. Hopefully my MacGyver fix will make do for awhile.
Wow, I would have spent around $2,500 for the windows I had to replace. I'm glad Nucamp and Transatlantic were able to help me out during the warranty period. Going to keep the new windows covered during the day when its stored and keep the roof vent cracked to allow for ventilation during warm sunny days.
@ReenieG, I would recommend adding a full trailer cover to your plan. Get a good one that includes both UV and weather protection. Also, be sure to leave the roof vent open slightly as well as opening the front window and driver's side windows to the first "locked-open" setting. I say the "driver's side" window, because it is a good idea to keep the passenger side window locked so a thief can't simply forcibly pull the slightly open window and reach in to unlock the trailer door. I hope it all works out for you and this issue does not reoccur. Too expensive!
Thanks!
@Bayliss I have a "good cover" however, here in AZ they disintegrate, just like my hot tub cover, which I have a cover for and then now have added a tarp over that since I'm not using it and... <drum roll> I was replacing the hot tub cover cover, which is over the hot tub cover on average every six months! These are "good covers" designed to "last" several years but don't.
I started covering my trailer this summer when I bought the cover, but haven't put it back on since I've been doing some mods and I didn't see the necessity wrestling with it (maybe I'm mistaken?) every time I went out to inspect and work on the T@B mods including the window issue.
If the warping is heat related, I'm not sure how much the cover would do... If it's sun related, well, then, yes, but I feel like this would be like closing the barn door after the fact.
Hopefully this will keep the windows from overheating. I noticed during the day when the sun is out it is much cooler inside the trailer than before I put up the window covers. I also put a wireless temperature sensor in the trailer and placed the digital display in the house, so if it gets hot in the trailer I will go out and open up the door and let it air out.
@RayJim Thanks for sharing!
