Back in the '80s when I was making regular trips from NY to FL and back, I usually brought a CB radio along in case of traffic jams, needing local directions, etc. With cell phones being ubiquitous now I haven't used the CB in years, but since getting our T@B we've made two long trips out west traveling through a lot of no-coverage areas.
I know there are at least a few ham operators and probably others on the Forum who may know, so my question is: how much is CB used these days or have most folks moved over to other formats like GMRS. Considering that I won't be giving it a lot of use, is it worth buying a small GMRS unit or handheld, or would I do just as well dusting off the old CB?
Richie, Mickie and Satchmo
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
0 ·
I am also a licensed amateur radio operator, Extra Class-N7SHG and have a mobile radio where I can talk. Like CB, often amateur radio frequencies in the VHF-UHF bands is dead, no one necessarily monitoring even the repeater frequencies and without a repeater, those Technician class frequencies are typically pretty short range topping out generally at around 100 miles typically, those bands are line of sight radio to radio. I have had conversations out to about 150 miles mountain top to mountain top, but that isn't typical, especially in a vehicle.
If you get licensed as a General or Extra Class and can get on the HF bands, you can usually have a conversation at long distances (HF bounces off ionosphere and can be used for communication for 1000's of miles depending on power, space weather, etc.), but bear in mind only a small percentage of amateurs have a mobile HF rig installed. So you won't be making local contacts typically, but can probably talk to someone someplace if you have an emergency, maybe even in another country. I have made contacts from Oregon to Hawaii, Canada and around USA with a very modest setup running low power and a wire for an antenna. Better antennas and way more power potentially gets you around the world. Amateur radio is a wide field, you can spend as much it little as you want, depends on what you want to do.
I also more recently started carrying a couple different satellite communication devices, one essentially a wifi hot spot that goes to an Inmarsat satellite in space and another basic texting device that uses the Iridium satellite network. Both are subscription and not necessarily inexpensive, but when you need comms they pretty much work if you have open sky line of sight to the satellite. I would probably go with one of the latter devices (I have a Zoleo, but other services are offered from Garmin, etc.) as these will allow you to get an SOS out and do short texts from just about anyplace on earth.
And of course there are cell phones which do tend to be spotty, but generally work along major highways, but out west I wouldn't count on that in emergency situations.
2022 - 11 trips - 34 nights
2023 - 4 trips - 21 nights
2024 - 5 trips - 51 nights
2025 - 5 trips - 18 nights
2024 Ford Ranger Raptor (10.5 mpg towing avg)
2018 BMW X5 xDrive35diesel (15.6 mpg towing avg)
2020 Toyota Tacoma TRD Off Road (11.1 mpg towing avg)
The Zoleo can send SOS and check INS direct from device, but has no keyboard, so must have BT to your phone to message. In a year I have sent ca couple test messages, but haven't had to use it for emergency cases. The device is also able to get weather for your location which is nice.
Both probably comparable products and I believe there are another one or two, all have the same basic ability to get a message out if needed.
Edit to add: Well, Spot now offers “Save our Vehicle” assistance at an additional cost. I’d prefer a device that uses the Iridium network though as I’ve heard it’s more consistently reliable.
"CB is pretty dead except for the radio Rambo's which is why mine is usually off and I suspect others too. When traveling I do tend to monitor because at least some truckers still have one and it can be a useful tool for weather and traffic hazards. Just be prepared for lots of tough talks foul language and generally low IQ behavior." GMRS seems to be the current tech popular with overlanders and off-road clubs, so I was wondering how much it had cut into CB use for monitoring weather, traffic, etc. while on the highways.
There are satellite phones and satellite data terminals that work similar to a mifi hotspot, but via satellite rather than cell. I have one of those too for work and can wifi to my laptop and do anything I need with internet connectivity, HOWEVER, the device is not inexpensive and the airtime is very expensive, BUT if you need connectivity for emergency use it is worth it. Check out the iSavi device on the Inmarsat satellite network as a entry point into that realm.
I would still say for general info when traveling that rough and tumble CB land is still probably best bet. Look for CB's that also get NOAA weather and maybe some of the MURS or GMRS radios might offer that too. I have a bank of memories on a commercial VHF radio for the weather and another for MURS and my CB radio also has the NOAA weather frequencies.
Sold 2023 Tab 400
Sold 2018 T@B 320S
managed by VE Smart Network
