Splitting a solar suitcase
I posted on the Tag Forum with no success so I thought I would try hear. We've downsized from a Tab 400 to a Tag XL. I have a Renogy 200w solar suitcase. It was great for the 400 but over kill for the Tag, and it is heavy. My thought was to take them apart and use just one rather then dealing with selling and buying a 100W suitcase. Renogy, without explaining why said don't do it. Looks fairly easy, unplug one panel, disconnect it form the other, and move the leg from the unused panel to the other.
Has anyone done this or see a reason not to?
Thanks
 20 T@G XL Boondock and 2019 Ford F 150 4x4
Madison, Wi
  • AnOldURAnOldUR Member Posts: 1,515
    Just guessing, but could it have something to do with the Renogy controller?
  • pthomas745pthomas745 Moderator Posts: 4,168
    I'm sure it can be done.  I've never seen a straight answer from any company when something involves any "can I do this" question.  Not that I blame them.
    How is the back of the panel (s) wired?   That would seem to be the hangup.
  • jrhameljrhamel Member Posts: 101
    @pthomas745 Their a is a set of connector wire that goes from a power box on one panel to the other panels power box then a another set of connecter wires that connect from the second panel to the controller. It looks like can just disconnect the one panel from the other with out doing any rewiring.
    Madison, Wi
    jrhamel said:
    Their a is a set of connector wire that goes from a power box on one panel to the other panels power box ....
    Wired in series or parallel?
    One way to find out, unplug the one panne, that is not connected directly to the controller and see if the remaining connected one still outputs voltage through the controller.
    @AnOldUR I think in series but not sure.
    @Denny16 Thanks, I will try that
    Madison, Wi
    edited January 2022
    Perhaps someone could school me in solar. I know that a panel that's rated at 12V can vary quite a bit. But could these be 6V panels in series to make it similar to a 12V? Would a controller that expecting an average of 12V function properly if fed something in the area of 6V?
    edit to ask, or am I completely off base?
    edited January 2022
    No, Solar Panels used for RVs are not 6VDC or even 12VDC, they are more like 15-35 VDC, depending on the sun hitting the panel.  Right now with low winter sun on front of the TaB (wrong side from solar panels on the rear), the solar panels are outputting around 16VDC.   The controller output voltage to the battery is 13.25VDC at 0.6 amps (battery is mostly charged).
    The solar controller reduces the voltage to match what the battery needs for charging, which is why you need a solar panel controller.
  • BaylissBayliss Member Posts: 1,392
    edited January 2022
    @jrhamel, I would recommend calling Renogy directly and talking to one of their techs. When they wrote, "don't do it," it may simply be because splitting the panels will void the warranty.  If not, I tend to agree that it may have something to do with the controller, or the fuse size (which you can change.)
    edited January 2022
    You're right @jrhamel the Renogy briefcases come wired in series (at least mine did, two 50W panels).
    I would expect to lose half your voltage if you split them. Don't know if they would push the current into the battery.
    2019 320 Boondock Edge
     - Sold Jan 2022
    I noodled around with this, just...because.  You have a 200 watt suitcase.  Each panel is 100 watts.  Both panels have "junction boxes" on the back.  The junction boxes appear to be identical across many different panels.  I couldn't find anything special about them at all.  The wiring of the two panels seems pretty straightforward.
    I'd have to study this more closely with a multimeter, but it certainly seems that each panel could be set up with the connectors of your choice simply by cutting the cables that connect them and adding new terminations.
    You should test it with a multimeter @pthomas745. I really think you'll find that the panels act like batteries do in series, the voltages add.
    Given that the Renogy suitcase panels combine for an output around 20V (in my experience) and are equal, each will probably produce around 10V individually. Just my understanding of electricity mind you, so looking forward to someone proving me wrong.  B)
     - Sold Jan 2022
    edited January 2022
    Actually, Solar Panels can be configured in parallel or in series. So as mentioned a multimeter will be a must.
    The photo posted above appears they are wired in series.
    Brad
    2020 400 BDL aka "Boonie"
    Concord, NC
    @CrabTab Wouldn't each panel act as a 100w panel? Does a 100w panel produce more than 10v? I have no idea, just going on logic, although that often proves to be wrong.
    Madison, Wi
    edited January 2022
    Each panel is 100 Watts but understand that Watts equals Voltage x Amps. So, you could have a 10-volt panel that will output 10 amps in full sun, or you could have a 20-volt panel that outputs 5 amps in full sun, or you could have a 30-volt panel that outputs 3.33 amps. All 3 are examples of 100 Watts.
    Which is why you also need a Solar Charge Controller as it will set the voltage and also control the amperage going into your battery bank.
    Brad
    Concord, NC
    edited January 2022
    @jrhamel
    As explained by @Dutch061, a 100W panel can be engineered to output different combinations of Volts and Amps.
    My hypothesis has been the 100W panels in your suitcase do not have the same design values as the 100W panels Renogy sells as an independent panel. The individual cells are joined in different combinations of series and parallel circuits within the panel.
    Since your panels are purpose built to be joined with a hinge, Renogy chose to attach them in series. This allows for a higher amperage output in each panel at the cost of a lower voltage. The lower voltage is made up for by the combination of the panels, voltage in power sources add when they are placed in series.
    Nothing trumps actual visual data, so measure it with a multimeter if you can. I haven't pulled my briefcases out. But I have looked at the photos provided by @pthomas745 It looks like the covers readily come off the black boxes. You should be able to place a meter probe on the exposed wiring before the little cylinder object (looks to carry the markings of a diode) and the other probe in the adjacent MC4 connector to measure the voltage across one panel. Compare that to the voltage from MC4 to MC4 (both panels).
     - Sold Jan 2022
    Thanks @CrabTab I will give it a try.
    Madison, Wi
    edited January 2022
    If the two panels are engineered to work together in series, than the controller may have a minimum voltage it will work at also, split the panels, the total voltage to the controller drops, and you not get any charge current out of the controller.
    We had this issue arise on a customer, who’s older solar setup was a series setup, and when one panel died, he tried to add a jumper cable to bypass the dead panel, but this brought the output voltage of the system be,ow the required minim voltage for the controller, which is a fixed program setup.
    @Denny16, Seems like that might be the issue. I think I will sell the 200w and buy a 100w.
    Madison, Wi
    Sounds like a good plan to me jr.
