I posted on the Tag Forum with no success so I thought I would try hear. We've downsized from a Tab 400 to a Tag XL. I have a Renogy 200w solar suitcase. It was great for the 400 but over kill for the Tag, and it is heavy. My thought was to take them apart and use just one rather then dealing with selling and buying a 100W suitcase. Renogy, without explaining why said don't do it. Looks fairly easy, unplug one panel, disconnect it form the other, and move the leg from the unused panel to the other.
Has anyone done this or see a reason not to?
Thanks
20 T@G XL Boondock and 2019 Ford F 150 4x4
Madison, Wi
0 ·
Madison, Wi
@Denny16 Thanks, I will try that
Madison, Wi
I would expect to lose half your voltage if you split them. Don't know if they would push the current into the battery.
2019 320 Boondock Edge - Sold Jan 2022
Given that the Renogy suitcase panels combine for an output around 20V (in my experience) and are equal, each will probably produce around 10V individually. Just my understanding of electricity mind you, so looking forward to someone proving me wrong.
The photo posted above appears they are wired in series.
Brad
Concord, NC
Madison, Wi
Which is why you also need a Solar Charge Controller as it will set the voltage and also control the amperage going into your battery bank.
Brad
Concord, NC
As explained by @Dutch061, a 100W panel can be engineered to output different combinations of Volts and Amps.
My hypothesis has been the 100W panels in your suitcase do not have the same design values as the 100W panels Renogy sells as an independent panel. The individual cells are joined in different combinations of series and parallel circuits within the panel.
Since your panels are purpose built to be joined with a hinge, Renogy chose to attach them in series. This allows for a higher amperage output in each panel at the cost of a lower voltage. The lower voltage is made up for by the combination of the panels, voltage in power sources add when they are placed in series.
Nothing trumps actual visual data, so measure it with a multimeter if you can. I haven't pulled my briefcases out. But I have looked at the photos provided by @pthomas745 It looks like the covers readily come off the black boxes. You should be able to place a meter probe on the exposed wiring before the little cylinder object (looks to carry the markings of a diode) and the other probe in the adjacent MC4 connector to measure the voltage across one panel. Compare that to the voltage from MC4 to MC4 (both panels).
Madison, Wi
Madison, Wi
