I saw someone else mentioned the new T@B 400’s has struts (gas or hydraulic....I don’t know which). I immediately sent Elsie a note that I needed them! I store my off season clothes in E-bags under that section of bed, so struts would definitely help.
I just installed then then today and I can lift the middle section with one hand now! No more worrying about the temporary dowel moving and the bed falling on me while getting something from the storage.
If you add the struts, be sure to take into the width of the 2x4 support on the bed. I had to move the front attachment over about 3/4”.
The right side strut.
And Elsie sent me a PDF with photos (attached) of which screws to use where. Plus it gave me an approximate location for where the struts hardware needed to be placed. I placed the rear hardware approximately 14” from the rear wall behind the sewer tube.
2013 Tundra TRD 5.7L
Massachusetts
Massachusetts
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
I have a canvas hanging bag on a wire frame that has my flip flops, dust pan/broom, and a few things that hang there, looped around the Froili pieces there.
With the bed section lifting so easily, I’m not sure it will work out with a handle. With all of this freezing weather I’m finding plenty of time to think about mods. I even “topped” off the glycol just below the max mark.
Those extra holes aren't mistakes, they're "Strategic lightening, strengthening web-connects". Think like an engineer....
WilliamA
2017 T@G XL
Nikki
Dealer installed smart shunt back there and I need to see if it's hooked up right because he wasn't sure.
Picked up my 22 400 today and it only has one strut and it seems fine for the task.
Hopefully your shunt is installed correctly. NuCamp installed ours wrong at the factory and I had to hook up the wires correctly. Thanks to the people on this forum for helping me with that.
My incorrect install.
My corrected Install. Ignore the circles I drew on the wires.
Close up of shunt.
Thanks for the help!!!!
