VictronConnect SmartSolar settings for Harris AGM batteries
KsublettKsublett Member Posts: 8
Do I need to do anything with changing any settings on the VictronConnect app that I installed to monitor my battery and solar.  I have the SmartSolar: MPPT 75/15 that came with the 2021 Tab 400 BD.  I saw another forum stating that you had to change some of it by it was all like a foreign language to me. Does anyone have a picture or cheat sheet on what they should be or do I just leave everything the way it was when I followed instructions to download.
(Title edited for search purposes.  Moderator)
  • MaxcampMaxcamp Member Posts: 330
    This is from battleborn batteries:
     programming for the Victron MPPT solar controller as follows:
    Absorption 14.6vF
    loat 13.5v
    Equalization 14.4v
    Absorption Time 1 hour total for pair 100 ah battery
    Most Recent Victron BMV-712 and SmartShunt Settings:
    Battery Capacity: Total AH of your bank of batteries
    Charged voltage: 14.2v
    Discharge Floor: 0%
    Tail Current: 4%
    Charged Detection Time: 3m
    Peukert Exponent: 1.05
    Charge Efficiency Factor: 99%
    Current threshold: 0.10A
    Time to go averaging period 3m
    Battery Starts Synchronized: blue button should be to the right
    State of Charge: leave alone
    Synchronize SOC to 100%: Leave alone, this device will sync itself at the top of the charge
    Zero Current Calibration: Leave alone
  • KsublettKsublett Member Posts: 8
    I have the two 6 volt AGM batteries that came with my Tab 400 boondock so I’m not sure my settings would be the same???
    edited March 2022
    No, your settings would not be the same as lithium batteries, and I believe Battleborn are lithium.
    If you can't find these settings here on the forum, you might contact your battery manufacturer tech support with the settings questions. Look at the app, press the settings (Gear) icon in the upper right, and select 'Battery'. There will be a list of settings that you can ask for specifics about.
    (I'm not near our Tab right now, so I can't elaborate. I can get mine for you later today, but mine aren't for AGM, just standard flooded.)
  • AnOldURAnOldUR Member Posts: 1,604
    My Vmax AGM’s settings are absorption 14.6V and float 13.6V. Equalization is set at 16.2, but the manufacturer said to turn automatic off and not use that function.
    Here are the settings for the BMV-712 that I used with great success.
    Setting
    Value
    Battery Capacity
    224
    Charged Voltage
    14.2
    Discharge Floor
    30%
    Tail Current
    .50%
    5 Minutes
    Peukert exponent
    1.1 using Victron App
    80% as per Harris Battery
    Current threshold
    .10 Amps
    3 Minutes
    Battery starts synchronized
    Off
    Here are the settings for the MPPT75/15 that I used, again with great success.
    I have since switched to Lithium.
    Brad
    2020 400 BDL aka "Boonie"
    Concord, NC
  • subkronsubkron Member Posts: 192
    @Sharon_is_SAM the battery link you provided is not working
    2022 T@B 400 Boondock
    South Jersey
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,012
    @Sharon_is_SAM That updated link works, thank you.
    South Jersey
