For newer T@Bs with the Lagun table
SLJSLJ Member Posts: 635
For T@Bs with the Lagun table...
Adding another table bracket by the door gives you a table you can use for more counter space.
A place to set things during the day you can easily reach from outside the door.
At night it gives you a headboard so your pillow won't fall off for those like me that sleep front to back (slides right into the bracket on end).
The big plus is you have somewhere not in the way to easily store the table at night!
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
    That makes a good storage position and setup, very nice.
    How did you get the table like that? (Bottom photo)
  • scott14scott14 Member Posts: 168
    Good question.   I was about to ask the same thing.
    Scott / 2019 T@B 400 "C@lypso" / 2015 Chevrolet Tahoe LTZ / Northern Illinois
  • SLJSLJ Member Posts: 635
    edited March 2022
    jkjenn said: How did you get the table like that? (Bottom photo)
    The plate under the table has a ridge that just slides into the upright. It's normally use to attach the upright post for storage to keep them together. Just turn the table up on it's end and slide it on.
    Thanks! I knew about thos but had com0letely forgot.
