jgriz
Member Posts: 10
I'm planning to drill a hole in the roof of my 2022 Tab 320S above where the microwave used to be, to
install a cellular antenna (Parsec K9 Pro). See the attached pictures
for where the antenna (cardboard) and hole will be. The antenna will be connected to a Pepwave 5G router mounted in the cabinet. I will splice into the nearby DC power wires.
My plan is to:
tape the roof and drill a 1.5" hole driver's side in the middle of the vent, 6.5" from the edge of the Tab.
drill up from inside (former) microwave cabinet a 3" hole around the 1.5" one, stopping at the aluminum roof. This larger inside hole will help with screwing on the antenna nut.
apply thread sealant to antenna bolt and drop through hole
bolt antenna nut from inside
apply silicon sealant around/under edges of antenna
If you happen to damage wiring, they would be easy to repair. Turn off the battery before drilling to preclude the chance of having an arc welding incident.
2021 CS-S - Enjoying the new layout
2011 Outback 3.6r
2011 Outback 3.6r
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
2011 Outback 3.6r
The whole idea is to get it as high as you can to get as good a signal as you can.
Maybe repurpose one of the Tv hookups, depending what year/model you have.
2011 Outback 3.6r
End result I am happy with. Signal is good WiFi works in and outside. One step closer to working on the road.
All that is remaining is Permanent power with rocker switch, Mounting Peplink and caulking antenna.
Down the road I plan on putting an all-weather Ethernet Jack on the outside and another on inside for the equipment to plug into that I am a programmer for.
2011 Outback 3.6r
My project is officially done. All seems to work great.
I am pretty happy with how everything turned out. WiFi works inside and outside providing a stable dependable platform for me to work remotely.
Switch to turn off PepLink router when not in use.
RepLink router mounted to access panel in cabinet.
2011 Outback 3.6r
The two worry items for me are where and how to drill the hole.
