Did anyone use an adaptor like
this one and plug into a regular 15 or 20 amp outlet. Will it hold up (assuming I don't run the AC on it)?
I also have my dryer outlet at home that is a dedicated 30 amp circuit, so this could be another option. However, I am not sure if it puts out 240v or 120v. I think the T@B can only handle 120. Also, the outlet has a different connector, so I would need an adapter.
Here is one. That one gives me a normal "household" type outlet. Then I would need a second adapter to go from that to the RV type plug. Lot's of adapters and I am not sure that the voltage would be correct. Does anyone know?
Thanks,
2020 T@B 320s Boondock Lite. 2015 Kia Sorrento EX V6 AWD
The dryer circuit for homes is 240V and should NOT be adapted to plug into the trailer. The plugs look similar but that is where it ends. Even electricians have made this mistake when wiring plugs for new owners and the results are a disaster for the trailer. Make sure any house wiring for your trailer adapted by plug or extension is 120V service.
That will also be the easiest option and allow me to connect to my driveway 120v plug. I might have been overthinking this
It too works well but does not allow me to use my EMS. However I am generally not too concerned about electrical issues at my house as compared to campgrounds. But my preference is to use the 30 amp cord and dogbone you describe.
https://tab-rv.vanillacommunity.com/discussion/comment/119623#Comment_119623
Fergie
I bought the 15 to 30 dog bone thingy and I guess this will be good for at least running the fridge and keeping the battery fresh. I will probably not turn on the AC or Alde with that configuration.
It seemed from reading the other thread that there are converters bringing the voltage down from 240 to 120. My Dryer outlet is a NEMA 10-30R. Is there a good adapter/converter that would bring down the voltage while keeping the amps at 30? Does any of them have the typical RV outlet at the other end so I can plug in my 30 amp shore power cable? Does anyone have a link to a good one? Is this a safe route to go?
Thanks,
2021 Tab400 Boondock; TV 2015 Jeep Grand Cherokee; Minnesota
South Jersey
