2016 Tab CS-S
We have owned this camper for over a year now and everything has been great. We recently changed the rear faucet and now when we turn on the water pump or the city water, the glycol is pushed out of the Alde system. So far in trying to figure out the problem, we have lost over a gallon of glycol from the system.
Please let me know what I can check.
THANK YOU!!
Jerod and Rebecca - 2016 T@B 320 CS-S
0 ·
The Alde glycol plumbing is completely separate from the domestic hot and cold water plumbing. Unless you did something very, um, creative, there is no way changing out a faucet would cause this to happen.
I can think of only one way that what you describe could occur, and it's not pretty... If the Alde core was corroded a hole could form between the glycol chamber and the internal HW tank. As you ran water under pressure through the Alde HW tank, it could seep into the glycol chamber. This would overfill the Alde's glycol plumbing, which would ultimately overflow at the expansion tank (which IIRC is behind the toilet in a 2016 CS-S) causing a leak of glycol under the trailer at that location.
I'm guessing here, but given my understanding of T@B plumbing, I don't see any other plausible explanations to what you describe. Again, this would have nothing to do with changing the faucet. If what I'm thinking is correct, it would be just a very peculiar coincidence.
If it is the boiler core at fault, I do not think you can buy a DIY replacement part. You will need to consult with Truma/Alde for options.
That is turn the various levers so all water bypasses the Alde. If the glycol no longer overflows/drains then the Adle tank may indeed be damaged - - - not a foul proof test but would be a helpful data point.
If you don't know how to set the valves (levers) this image might help
((better descriptions can be found on this forum))
Per my speculation above, is the leak between the glycol chamber and the internal HW tank? Was the glycol overflowing at the expansion tank?
Sorry for all the questions, but I think you are in previously uncharted waters here so I'm very curious about the details and how you eventually resolve this. Sorry you had to be the pioneer, though... :-/
Thank you to everyone that gave input to help solve our problem!
So, as I understand what you've shown, the location of the corroded glycol tank wall was the weld between the double tank in an area near where the longer glycol pipe enters the tank. That would be the glycol exit pipe near the top of the unit, if I'm not mistaken? If so, I would surmise that this location would be more prone to corrosion, since that's where air in the glycol system would tend to collect at a high point, and the oxygen present would then contribute to the oxidation process.
What an amazing job you did tackling such a huge project. Congrats!
PS: The heating elements appear to be in great shape. Also, it looks like there were a couple of other spots in that last photo with some possible corrosion, with some of the white deposits like we've seen in our convectors.
Thank you @fineline72 for your effort & aptitude, and for explaining things to us in detail.
Your efforts, like many here, really do help us all understand things a little better every day.
SW Montana USA
2020 Tacoma TRD Off-Road
2015 Dodge Ram 5.7 Hemi
