This is on sale right now at Amazon for $208 after 20% off
Renogy 100 Watt 12 Volt Monocrystalline Off Grid Portable Foldable 2Pcs 50W Solar Panel Suitcase Built-in Kickstand with Waterproof 20A Charger Controller
Thinking about getting one. It has a controller, so I could presumably connect it to my T@B battery via the controller and make my battery last longer while dry camping.
Would love to hear some thoughts... tips... other (better) options... or if anyone thinks it's unwise to go this cheap.
Thanks!
2020 T@B 320s Boondock Lite. 2015 Kia Sorrento EX V6 AWD
0 ·
2013 Tundra TRD 5.7L
Massachusetts
Odessa, Fl.
2019 T@B 400 Boondock
But as @grubbster noted, hard panels are significantly heavier (with the cheaper panels even heavier than the Eclipse) and I needed more than 100w because solar in my region isn’t all that efficient. I would have considered a second Renogy soft case, but they’d been discontinued by that point. Instead, I ended up with a 200w Bluetti soft suitcase found on sale, using the same controller and cables I’d set up, and it’s simply better built than the Renogy.
I actually ended up going even cheaper, with a 60W Eco-Worthy for $80.
Has a primitive controller and a 10 foot cable (the controller being about half way, but I would consider moving it closer to the battery if that is really an issue). It is also really light.
This allows me to start easy with a minimal investment. I a lot of other variables to figure out before making more investments in battery and solar.
I will let you guys know how this one works after a couple of weeks.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
Not sure if I understood your post correctly, or if you misunderstood mine. Thanks anyway!
Huntington LI
Overall, I like it and it works well. Make sure you understand how to connect the cables to your battery. It is easy to get the polarity switched. Verify it with a Volt Meter before connecting. There are some good discussion about that on this forum.
Between the suitcase and the few hours the roof panels got full sun, I was able to get the 100 AH AGM up to 85% each day while off the grid. Would be a problem if we had cloudy days. I don't think I will use the 12V only fridge on my next boondocking trip. Too stressful making sure the battery is fully charged.
2020 F150 2.7l V6 Turbo
Tucson, Arizona
Huntington LI
Make sure you check the polarity. With these solar ports both sides are a power source (battery and solar panel). Typically the power source in a circuit has the + terminal in the covered female terminal. Zamp has chosen to make the + terminal on the solar plug the covered female terminal, thus making the exposed male terminal on the tub the + terminal.
Huntington LI
