The other day I was crawling around my trailer checking things over and found this :
All four of the rivets connecting the tongue (right side of pic) to the main trailer frame went AWOL. I did check for cracks in the area when I got the trailer close to a year ago and they were definitely present. Somewhere along the last 2500-3000 miles I dragged it around they have failed. I did find all four inner pieces in the channel or the underbelly.
It's an easy fix, drill the holes to 3/8 and use grade 8 hardware tightened to 5 ugga-dugga with a 3/8" impact gun.
FWIW, this trailer is a 2015 and was owned by Dale before me. I know he put quite a few miles on it and it's anybody's guess why that happened. Just keep an eye on it ....
The collars are not broken off flush but 2-4 mm below the contact surface. Makes me wonder if the collar was not clamped on sufficiently.
2020 TAB 320 S Boondock Lite
2019 Toyota 4 Runner
Puget Sound Country
Could breaking below the contact surface be caused by over torquing causing stress in the little 6mm bolt bolt?
Bottom line, you can have the "correct torque" but have an incorrect "clamp load". The clamp load can be too high or not high enough, either of which is not a good fastener installation.
It is very possible that the "tensile stiffness" of the "Huck Fasteners" is what the design engineer for the frame wanted to have some flexibility. Huck bolts are installed using a tool that stretches the bolt and crimps the "nut" at the same time to create the "clamp load". It is possible that there were tool issues or the person installing them was not properly trained, and they were "over stretched" which is likely why they failed.
Granted, it is a problem since they failed, that point there is no dispute on.
Brad
Concord, NC
Seeing that Huck markets how fast these can be installed I have a suspicion why lock bolts are used ....
Will be crawling under the Tab today!
