I have done a search here after this turned up yesterday in my less-than-two-years-old T@B 400. Heat has worked fine, but now unit comes on, makes flame sound for thirty seconds, cuts off, tries again (that's what it sounds like), then throws a Gas Failure. There is some warmth. So it's lighting but not staying lit.
Read some troubleshooting tips here and have done some:
- Reset on panel
- Unplug 12v from the Alde
- Turn off gas and sloooooooooooowly reopen valve like on my gas grill, which slows to trickle if you open it too fast
- Exhaust flue is clear and I even vaccumed it out.
- Soapy water test on regulator connections and Tee-intersection at rear. No bubbles.
The stove gas rings work fine. Full propane tank (although this started when tank was near empty -- I thought that's all it was at first).
One curious thing: With all the recent discussion of glycol, I checked my reservoir and it's sitting at Max. I have never touched the thing since purchase; never needed to because heat has always worked wonderfully. About to draw it down with a siphon tube. I don't see how that could be related, but ...
Thanks for any input. I emailed Alde and they have been less than helpful. ("$280 for a new circuit board and we don't have any anyway, have a nice day")
jeannie
I've had Gas Failure Notice / Shut down when the TB battery voltage was low . . . but not low enough to cause the Alde to issue a Low Battery Notice.
Connecting 7-Pin to TV and running TV engine cleared the (false) Gas Failure.
Adventures: 51 Nights: 322 Towing Miles 41,200+
2020 Toyota Tacoma TRD 4x4
2020 TAB 320S Boondock Lite
TV: 2018 Jeep Grand Cherokee
I have written to the nucamp help address and am waiting to hear back.
Thanks to all you helpful people!
Just hoping to be able to talk to someone knowledgeable at NuCamp. Still thinking of unscrewing all the under-shielding to check for gas line damage by squirrels, but there's no gas smell or gas volume loss from bottle so I'm putting that off.
I think you're right though, the fact that you are showing an error on your display indicates that the system is still powered up.
When my 'thermal fuse' blew, I'm pretty sure it took out all the 12V from the board. I'm sure your display and it's brain requires 12V to give you that message.
Sorry, no help.
Can anyone tell me if this is a simple item to replace? Seeing them on the web, not sure what specs I need to be matching.
And yes @pthomas745, I do doubt the leaky line thing, hence not taking off the bottom of the camper.
The problem has been REPAIRED, by my dealer. I tried my own troubleshooting until December, talking with NuCamp and Truma, and finally got a service appointment for four months later. The dealer had my T@B 400 for a month, April 4 to mid-May.
It was determined to be a faulty PCB, as I first suspected. Now the furnace fires up on propane once again. Heading to the beach in 9 days. :-)
The PCB failed within the 24-month warranty period described in the Alde manual (it quit at 21 months). Still waiting to hear from NuCamp about whether my $500 repair bill will be covered.
So that's where we stand.
