I'm wondering if anyone has used the Five Star Chemicals product "Starsan" for sanitizing their T@B fresh water system.
I have used it for years in my home brewery. You use a relatively small amount (1oz) per 5 gallons of water. Run it through the system and drain. No rinsing needed, which makes it much easier to use than bleach. It does leave behind a plethora of bubbles/foam, but these bubbles are 100% safe to mix with fresh water (or wort) afterwards and impart zero taste or odor. The slogan "Don't fear the foam!" is commonly used when Starsan is utilized for this reason.
2021 T@B 320S Boondock | 2019 BMW X3 M40i
0 ·
2019 Tundra Crewmax aka Hoss
SE Louisiana
SE Louisiana
managed by VE Smart Network
This is interesting, I will try to do a test with it as well.
2022 Ford F350 Tremor | 2022 Cirrus 620
