I guess they have profit margins that shine when they use defective and/or alternative components or somehow can't manage to explain what actually is installed in the new years model. And can't seem to pass along that info to their dealers. I got so much bad info from my dealer but I was so lucky to find this group. However, I did not know that I had to be an electrical engineer to own a T@B.
2022 T@B 320 S Boondock "UGA", Jeep Gladiator Overland
North Georgia
0 ·
Southern Maryland
2020 Tacoma TRD Off-Road
The TaB and other nüCamp products stood out in the mass of poorly built units I had looked out. The only other manufacturer coming close was Airstream, which was more money yet. We went for a previously owned TaB400, which was in grand condition and at a good price at the time. Local dealer support has also been grand.
While there have been minor issues, they were quickly resolved by nüCamp and our local TaB dealer who provided excellent service. The TaB is well made, bit as all things mechanical, tunings can and do go wrong. It’s advanced systems, like the Alde have a bit of a learning curve, but knot that complicated or difficult to work out.
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
Just last month, even one of the largest T@B dealers in Maryland didn't know how to properly change the glycol. I had to intervene for my friend and call NuCamp and Nucamp had to call this dealership and explain the correct way to change glycol! When my friend asked if they have the special pump from NuCamp, they replied yes we have it but we don't use it we just do a gravity drain!!!!! (Which only gets out about half of the old gylcol)
Fortunately so far I haven't had anything major fail that required a repair shop visit other than a frayed brake line on my 2019 400 which I could have repaired myself but amazingly that happened in route to the repair shop for general brake service/maintenance.
Edit: forgot to say on the 2022 400 I had to replace the mixer valve day one. Someone used a power tool to adjust it and its just a hand adjustment. Fortunately that was so easy a child could have switched it out but I just got lucky with that.
But I am very thankful for this group as I have learned a lot and will continue to do so and hopefully will learn some craft skills so that I can deal with issues myself as it doesn't help to be out and about and schedule a service appointment 2 months later.
North Georgia
As far as quality, yes Nucamp tends to use the best materials…but humans put these things together and humans can suck sometimes. That’s been my biggest issue with our 400…lack of overall craftsmanship. Yeah, the components may all be made in China but it’s an American worker overdriving screws, not aligning cabinets, leaving too much slack on the brake line, etc.
We’ve owned a poor quality popup camper and yeah, those are a whole other story. If Nucamp is all you’re familiar with and you walk into a Forest River product…yikes. No comparison. I just wish the craftsmanship was a level up. That’s all.
It boggles my mind that NuCamp doesn't use brass connectors on the pex pipes! With the amount of vibration the system has it begs for leaks! I understand that it's more costly BUT we do pay a premium for this trailer (and it's a real pain to fix some of these). Yes I use and check that my regulator is correctly limiting the water pressure.
After the summer high travel season I hope to rebuild both the hot and cold water manifolds with swagged but brass connections and Sharkbite outlets for ease of future repair. From looking at this plastic tree of pipes it has to fail sooner rather than later.
managed by VE Smart Network
My previously owned 2021 T@b400 BD had 7,000 miles and approximately 6 weeks of every day use when I purchased it. I spent the past few months learning, installing some upgrades, performing required maintenance and experimenting with the systems. I am pleased to say that every system has performed as it should and I have found no issues with quality control. Knock on Wood! (Or in yiddish, we say "Don't give yourself a Keinahora".
While it is likely that we do not hear from the great majority who have not had problems, I still agree with @CCC in that NuCamp could and should do better with communications, quality control and not being penny-wise and dollar-foolish by installing cheap fans and cushions in high-end expensive campers. And why not have re-calls like the auto industry for defects found after fabrication - as apparently done by Airstream with the Alde Glycol change?
I am happy with my T@b 400. I know these are difficult times but, like any business, continued success for NuCamp depends upon Delighting Your Customers and the small things are often the big things.
And I agree with @manyman297 that RV's can be built to last but today we look for things to be cheap, not necessarily sustainable.
Oneonta, NY
If you are having an issue you feel is a factory or construction caused problem or defect, contact nüCamp Customer Support and they will work,with yiu to find a solution. I agree not all dealers are capable of good post sale service, but a majority are, and nüCamp is in the process of providing training to those dealers to provide good post sale support and service.
Keep in mind this forum's purpose is to help owners fix, modify, upgrade, etc so you are mostly only going to hear something is wrong on this forum. Most RV forums are used for this same purpose. Take a look at any of the others including Airstream (which I have used) and you will see the same tone and subject matter. Airstream was able to do a recall because they only use the Alde on one model of their very high end trailers ($150k+), so the number of units they had to fix was fairly low. For Nucamp to do a recall on EVERY SINGLE trailer they have ever built (or even just a few late model years) would put them out of business over night.
I also know the pandemic has put unimaginable stresses and strains on every aspect of human life so the fact they can even produce an RV these days is a big undertaking. You can't even get tampons, baby formula and cat food anymore!
First topic, NuCamp Build Quality.
NuCamp (like all manufacturers) rely on suppliers to provide the majority of the components used to build the final product.
With this said, the majority of ALL issues with new products (read this as most anything) is tied to the quality and supply of those components. Some which are easily identified as "not acceptable quality" while others are not so simple.
To begin to even think that NuCamp (or any other company) would intentionally ship defective finished products is just not sound thinking (or business). The cost of warranty repairs after delivering to an end user is astronomical in comparison to fixing it "in-house" before shipping. It is 10 x higher after it leaves, if not more.
Unfortunately, due to the recent 2 plus years of the "pandemic", constant supply chain issues, substitutions, worker shortages (in all business nationwide) we are not dealing with what anyone could refer to as "Normal times". I don't have a crystal ball to be able to tell you when they will (if ever) return to what we view as normal. In the interim, we have choices that can be made. Either buy things knowing that there will be return visits due to these challenges that are beyond the manufacturers control or keep what we have.
2nd topic, regarding dealers.
As in all Sales & Service operations, there are really good ones and some that just "think they are". The only way to find out is to speak to people who have done business with them in the past or dive in and take the chance yourself. I originally came out of the Auto Industry and can assure you that there are some really good dealerships (and private repair facilities) and some that are just plain horrible.
I am blessed with the knowledge and ability to fix nearly anything that I come across as a problem. It is not because I can't afford to pay someone, it is the simple fact that I hate to pay money for the better than average chance that I am going to receive what I view as a "sub-standard" job.
If I had to rely on a dealership, their reputation would be a major deciding factor on the brand I buy. Meaning if they sell Brand X that I really like but have a horrible reputation with them. Maybe I look at Brand Y or go to another dealership location for my purchase.
Final Commnet, NuCamp customer service.
It has been my experience that NuCamp goes above and beyond to satisfy their end users. They certainly have "went the extra mile" for me with a couple of issues that I had. I couldn't be more pleased, and I know countless others who have also had this great experience.
As far as quality for the money, the prices have gone up significantly since I bought our 400 BDL in March of 2020. But it isn't just NuCamp that has price increases. I would challenge anyone to find the quality of what NuCamp builds in the price range they are selling for. I have personally looked at other campers in recent weeks (this includes up to a 100K unit), and I would easily say that everything I have looked at is way beneath NuCamp quality.
So, be patient in these difficult times, seek out a dealership that is knowledgeable for all of your needs, or if it is is realistic, learn as much as you possibly can. It is a wonderful benefit of being able to do things for yourself - especially if you are not near anything.
Brad
Concord, NC
I too choose to do whatever I can myself on the camper because I know it will be done right...or at least I can blame myself when it doesn't work out. I've just never had a great experience when I've hired anything out. A lot of it is me and my expectations I guess but I can count numerous friends and family members that have hired out something and it's turned into a nightmare. Nobody is perfect but I feel like we have a workmanship issue in the states at least. A good craftsman is hard to find.
We tend to scapegoat and blame China for quality and yes, that's largely true. But there's plenty of things made here that just plain suck. I'm too young to remember when quality products came out of the US but I hear about it from my parents and other relatives. All I've really ever known is junk to be honest. Things break. Nothing lasts. It's just expected now. Built-in obsolescence. It's not necessarily China's fault. It's the companies shipping jobs overseas to save a penny and it's our fault as consumers for expecting everything to be affordable.
Regarding customer service, yes NuCamp is amazing. I've posted on this forum how amazing they've been to work with on all of the issues we've had with our camper. This is where they shine in my opinion. Companies could care less after the sale so it's great to see NuCamp standing by their product post sale.
As for quality, we have had three defects so far. Two are on the supplier - Dometic!! The locking knob on our fan broke and our glass top on our stove stopped staying up after three correct uses. Interestingly our dealer said both of these are known issues and the parts will just break again. This is why I mentioned in another thread my dismay at the low quality standards in this category in general. Since the knob will break again - and I got super glue to work for now! - we didn't bother replacing it - but I did want Dometic on the hook for a badly engineered stove top! So that is being replaced.
The third defect was an install issue. One of the brackets on our convertible seating cushion started to pull out. It looks like a screw was stripped and one screw was never fully screwed in. That's likely on nuCamp for sure. But when I called nuCamp, I was amazed at how quick they were to respond. I was worried it would take me too long to get a dealer appointment before our next camping trip, so I wanted to get their advice on if I should repair it myself. They wanted to ensure I tried warranty service first, and they assured me the dealership - the tech knew the service manager! - would get it done right. But they also offered - if the timing doesn't work, call them back and they will see what they can do!
Well, the dealership did the right thing too! They squeezed me in knowing we had an upcoming trip, and they got the cushion fixed in time for us to camp this weekend! The stove top is still not fixed, but that's not on the dealer - the part is on order. It will take weeks to come in, so we will just go back one day for a quick install.
So I admit we are early in our journey, but so far I have been very happy we decided to get a nuCamp trailer. I still aspire to be as independent as many of you and eventually do a lot on my own -especially when the warranty ends! - but I have a lot to learn! Thankfully I have this great forum as a resource!
Kevin
The parts and the people change over time. When my parents purchased a class C in the late 70's, it was pretty well built. The thought of taking it back somewhere to make repairs never crossed our minds. It was ours and we fixed the anything that went wrong. That's what you did back then. The first 6 months were a little busy. After that we had several years of trouble free service.
Now, I have a 320CS. The parts, particularly the wooden parts, are manufactured better; however, there is much more plastic. If you look at modern RVs, NuCamp is comparable with the top: Airstream and Oliver. They just play in a different segment of the market.
People currently expect someone else to make the repairs. I'm still stuck in the 70's mentality. I fix my own until there is a recall or the need for special tools I don't have.
"The more things change, the more they stay the same."
"Just Enough"
There is always room for improvement. Human error is manageable. Results will align with expectations.
While there are negatives associated with Amazon, they have achieved what few thought possible only a few years ago by setting expectations previously considered unrealistic. I live in a rural area and order something I need on Sunday afternoon and it is at my door on Monday. If I don't like it, I drop it off at the UPS store unboxed and my refund is received before I get back in my car. This is a result of setting expectations and systems that never say "good enough". I love my T@b400 and have no complaints so far. I want to see NuCamp thrive but no company can thrive just by focusing on what they do well. They thrive by talking about and targeting what they can do better.
NuCamp has a great product and good customer service. We help them by pointing out what can be done better and I bet they appreciate that.
Oneonta, NY
2020 TAB 320 S Boondock Lite
2019 Toyota 4 Runner
Puget Sound Country
I too spend more money with Amazon than I care to admit, but it is primarily driven by the inability to find things locally or find them at a reasonable price. I agree with you on the ease of doing business and the ease of return with Amazon, but at the same time we are starving out the "mom and pop shops". In the end when Amazon (and other big box stores) are the only ones left, we will be left with nobody to actually provide you any help when you have questions. In addition, when they are all that remain, and the competition is gone (competition is healthy) they will have total control of the pricing.
Brad
Concord, NC
I did point out that Amazon brings many negatives in my statement but I was wrong to use Amazon as an example as it distracted from the one point I tried to make.
Many companies spend a great deal of money and time surveying their customers in an effort to learn what they could/should do better. This forum is an excellent resource for NuCamp in providing them with that information and I am sure they appreciate that. We shouldn't get defensive or make anyone feel wrong for pointing out weaknesses. It is in NuCamp's, and our, best interest.
Oneonta, NY
