Hi Everyone,
Were getting ready to go out on the maiden voyage and while loading it we noticed the AC is not cooling the camper at all. Unit is a 2022 Tab 400, It feels like just the fan is on, but I hear the AC kick on. I also noticed im not getting any condensate from the drain line, any ideas?
Next, did,you remove the outside vent cover? If the cover is left in, compressor will start, then stop when it heats up. Sounds like your issue
If the answer to,1&3 is yes, and the cover (no2) has been removed, you got an issue with the CoolCat, contact your dealer. Is this the first time you tested the AC? Sorry to hear about your issue.
yes it is set correctly and yes the cover is off. right now ambient in the RV is about 96 I set it to 87 I can hear the compressor come on but I'm not getting cold air at all. Im afraid i have a R410A leak, I looked to see if there was a Thermal switch i could reset but couldnt see one
I did test it last week and it blew cool air I'm not sure what could have happened to cause this.
i work in industrial equipment so I talked so some of my refrigeration guys and they are thinking the same thing
It likely is the refrigerant if you hear the compressor cycle.
A large improvement can be made by making a simple baffle that helps separate the flows. Something similar to the picture made from cardboard at first to prove a design and then cloroplast or something more weather resistant will make a startling difference in tough conditions.
There is a similar thread with other examples.
https://tab-rv.vanillacommunity.com/discussion/comment/169322#Comment_169322
Sorry to hear about your Air8 issues. Did your mobile repair main measure the discharge temperature out of the vents? If so, what was it? Also, what is the outside temperature? What is the temperature inside the TAB?
Is there no condensation coming out of the tube below the trailer (assuming you live in a humid vs. dry climate).
You are getting no temperature drop at all out of your vents, just warm outside air even after running for about 30 minutes?
Just to double check, and I'm sure you have it right...but you have it on AC mode (snowflake) and not dehumidication mode (teardrop).
Also, Just curious , did the dealer show you or tell you more about the two different Air8 models. I've done a lot of looking to find out more info about the Air8 and how it works and have only been able to find info on one model. I've mailed Elwell a few times and they have never mentioned anything about more than 1 model.
Thank you,
Southern Maryland
