I've searched and read this or other forums info regarding Grey Tank Treatment that I have been able to find and still don't see a definitive re:
1-Not treat the Grey Tank with anything,
2. Treat with holding tank treatment that is the same product as Black Tank treatment
3. Treat with specially formulated Grey Tank treatment.
Based on what I've learned, I'm leaning toward periodically treating the Grey Tank with the same product as the Black Tank treatment. Any thoughts on this?
2022 T@b 400bd
2022 F-150
Gratitude
0 ·
South Jersey
Now I put 1/2 scoop into a protein powder shaker bottle, the type with a ball whisk inside. Fill with water, shake until thoroughly mixed, pour down drain. Follow up with more water.
You need to premix the HC powder in water first or you will have Victoria’s issue above.
TV 2022 Highlander
We use a mixture of 50% Dawn dishwashing soap and 50% Calgon liquid water softener. We pre mix 2 ounces in a small plastic bottle, (19 gallon gray water tank), the day before our last night of camping empty mixture down the sink. Drain tank (in appropriate dump station) the morning before departing for home. Clean tank ready for next trip.
Do you leave the tank empty after you dump the tanks? I think that is when I would want to use Happy Camper? Does the 50/50 solution do anything while it's sitting overnight? Do you only use the 50/50 solution in the gray tank? Why not use it in the black tank too? After 3 seasons of use I'm still confused over the best solution for managing black and gray tanks. Thanks
TV 2018 Toyota Highlander 3.5L v6
TV 2022 Highlander
