Serious question here. Wondering why one needs a battery if you ALWAYS operate from shore power in an RV park? Appears that the unit running lights operate without a battery, as long as your power switch is turned on as you travel. So, seriously, what purpose does the battery serve if you do not need power in the unit at other times? Thanks.
0 ·
Ive had my battery out for a few months while not using the unit, and placed on trickle charge. Needing to move the unit a couple of miles to a new parking place, I was surprised that my running lights worked with no battery installed. I did have the power switch in the "on" position, which I have left on. There is nothing to run down without the battery in the unit, right? Thanks again for the "pooled knowledge".
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
Regarding your main question, aside from the emergency brakes, it’s useful to have a battery for stops along your drive, so that using the water pump or lights doesn’t drain your vehicle battery…if your 7 pin even allows use when the ignition is off. It’s also useful when you get to the RV park only to find the last available site has a defective power pole, and yes, that’s more common than you’d hope.
nuCamp tech response to me below:
"Your unit would have come with brakes. The 7-pin connector plug has the brake line in so you do not need an additional plug. However you will need a brake controller to activate the brakes. There are several options that you could pursue. We would recommend talking with a trailer/camper dealer to determine what works best for your car."
TV 2025 Telluride X Type
