Yellow fluid from Alde heating system coming through fresh (hot) water lines
FINALLY dewinterizing this year.  I used the blowout method vs. antifreeze to winterize.  Now that I am dewinterizing and filling the tank, yellow fluid is coming out the hot water lines.  Any ideas on what I messed up to cause this and how to fix?
  • Horigan
    Horigan Member Posts: 907
    I can't see how using the blow out method would damage the Alde heat exchanger, unless you pressurized the system above 50 psi.
    Are you losing Alde fluid at the reservoir?  If so, you likely need a new Alde unit, unless they sell just the heat exchanger.  I would take it to a dealer familiar with Aldes.
    Rich
    2019 T@b 400
    Bellingham WA
  • ESH
    ESH Member Posts: 27
    Thanks for the quick response.  I was very careful to not go above 40 psi when using the blow out method.  I have been losing fluid at the reservoir, but that pre-dated this issue and I believe is due to the mixing valve getting stuck.  Any other ideas?
  • Horigan
    One test I can think of is to hook up city water with a pressure regulator and see if the Alde fluid level increases in the reservoir.  That would indicate a breach in the heat exchanger.
    Rich
    2019 T@b 400
    Bellingham WA
  • ESH
    Good idea.  Just tried it.  No change.  Mystified.
  • Horigan
    Are you sure the fluid from the tap is Alde fluid?  Another test would be to drain the hot water tank, then put a bowl under the drain and run the Alde to see if any Alde fluid drains out of the hot water tank drain.
    Rich
    2019 T@b 400
    Bellingham WA
  • ESH
    Will give that a try.  Same fluid for sure (same color, viscosity, smell).
  • ESH
    Hey Rich.  Drained the hot water tank and refilled the glycol.  Only water draining out of the tank currently.  Only thing I can think of is that there is a small leak in the Alde tank that is allowing for cross contamination.
  • Horigan
    The only place they are in close proximity to each other is in the Alde heat exchanger.
    Rich
    2019 T@b 400
    Bellingham WA
    MuttonChops Member Posts: 2,057
    At least one (maybe a couple) forum members have reported a failure in the Alde Heat Exchanger that resulted in glycol entering the domestic (hot) water system (lines).
    They were Alde production weld failures or damage caused by incomplete wintherization.
    IMHO you should have the system checked by a qualified Alde dealer . . . your out-of-pocket will depend on the trailer age and warranty status.
  • ESH
    Will do. Thanks.
  • subkron
    subkron Member Posts: 205
    I think I have the same issue. We were camping this past weekend and noticed that when I used the outside shower (to fill a dishpan) via the hot valve it initially had a yellow/brown tint to the water then cleared up. The photo below is after the unit sat overnight. This was only our 3rd trip out so I will need to get it to a dealer.
    2022 T@B 400 Boondock
    South Jersey
    @subkron - how is the level in your glycol reservoir?  Others noticed that it would drop when they turned on the water and pump.  If it cleared up, I would wonder if their was old water sitting in your shower line.  Have you seen it with any other faucets?
    ScottG Administrator Posts: 5,691
    Wouldn't a 2022 have the bluish Rohmer fluid? That looks more like sediment/crud from the lines rather than glycol.
  • Denny16
    Denny16 Member Posts: 5,430
    I agree with Scott, that is not glycol, but bad, dirty water from the line.  I always flush out the water lines before heading out on a trip.  That way, not surprises.
  • subkron
    @Denny16 - I always flush the lines before starting a trip and for this one then filled the fresh water before leaving since I was boondocking.
    @Sharon_is_SAM - I only noticed it the outside shower since the water was going into that white dishpan. My glycol reservoir seems normal, if it is a small leak (since it clears quickly) it probably is not noticeable at the reservoir.
    I tried a test. Last night I flushed the lines by setting the nautilus to city water, put the water in, opened the hot and cold drain lines, run water through and then closed the drains. I let the system fill/pressurize and then using outside shower nozzle discharged both hot and cold into a pan, nice and clear. I then let the system pressurize again, and then shut off the incoming water at the nautilus input (I have a  valve at the end of the hose). I then let the system sit overnight pressurized.  When I tried the hot water via the outside shower this morning I get the same result as I mentioned, the small amount yellow tint before it becomes clear.
    Any ideas on what else to try before I give a dealer a call?
    South Jersey
    What glycol is in the reservoir - Century or Rhomar?
  • subkron
    Don't know, it was built in Nov 2021.
    South Jersey
    What color is it?
  • subkron
    I'm not at the trailer, but I don't think it is the yellow color in my pic  Does the glycol change color if mixed with water? I also find it odd that it comes out only initially discolored, then clear. Whatever it is is not really mixing.  I'm going to perform a few more flushes this afternoon and see if I can get to the bottom of this.
    South Jersey
  • Denny16
    Whilst flushing the trailer’s internal lines, it is easy to overlook the outside shower lines, which are a separate run off the inside shower, and water can get trapped there.  But since it came back after flushing the line, this is a mystery.
  • Pintoplumber
    Pintoplumber Member Posts: 182
    Unless you’re filtering your water, campground water isn’t necessarily clean. Did you ever look inside your toilet tank at your toilet at home? There’s almost always discoloration in there. The water we drink be it from a well or city water isn’t as clean as we would like. If your water source has iron in it there’s even more discoloration.
    2016 320 CS-S  1954 Ford F100  2017 Chevy suburban  2023 Chevy Silverado 1500
    @subkron - assuming you purchased your 2022 new, it should have the bluish-greenish Rhomar glycol.
  • subkron
    @Sharon_is_SAM. Yes, purchased new in feb-2022.
    @Pintoplumber. The water comes from ort whole house water purification system so this is not city or well. There is no way that crap made it thru that multistage system.
    After I had filled from a prior trip I blew out the water house with my air compressor. I have a filter on it but I fear it is not that effective. I'm thinking I may have contaminated the hose and the subsequent fill transferred some contaminants to the system. Not confirmed, but after a half dozen flushes of the system it has cleared. I had to put the trailer back in storage (HOA, need I say more?) so no more data for now.
    South Jersey
  • BrianZ
    BrianZ Member Posts: 1,770
    edited August 2022
    @subkron, glad you figured it out.  I know air compressors will condense humid air inside the tank & cause rust.  Ours has a srew type release valve under the bottom of the tank for blowing out water condensation after use.  It usually has some rusty looking drips since I often neglect to open it after use.  Can't say that I've ever seen it blow out anything rusty looking, but ours is a big tank & air hoses are at the top.
  • Denny16
    Most large compressors have a moisture filter on the air output side, to remove the moisture that forms in the tank, so you do not see it in the air stream.
    @Robermcm, I moved the comment (below) you had originally posted here to your other recent discussion. I suspect you will have a better chance of getting good advice if you keep the history of your Alde issue contained in one place.
    Robermcm said:
    I was topping off my Alde reservoir and it kept accepting it. An entire gallon.  This trailer was used and I just bought it. The reservoir was below the min mark when I got it.
    Before I went out to get another gallon, I thought I’d check the winterization, so I opened the hot water yellow valve, the cold water yellow valve and the 3 outside valves (hot, cold, fresh). Water with pink antifreeze ran out for a bit. But the hot water line kept running. I gathered some of it in a clear container and it’s almost pure Alde green glycol!🥴
    is my boiler shot or maybe the flow heat exchanger? Clearly glycol is on the hot water line. How should I diagnose more, or is it already a done deal? I’m screwed?
