On day 10 of a 30+ day Safari in NE Utah now, all systems working great since I set the Alde heating system on high altitude and turned the propane a few times to get flow for the stove, but I can not for the life of me get the Alde hot water working. I have been without cell or internet for the past 4 days, hoping one of you might offer quick hints, don’t have a good connection to search. Enjoying the hell out of the freedom to roam.
2022 T@B 320 S Boondock "UGA", Jeep Gladiator Overland
North Georgia
0 ·
North Georgia
de hot water tank.
North Georgia
North Georgia
North Georgia
North Georgia
North Georgia
Southern Maryland
North Georgia
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
If the red tube is hot before the mixing valve how hot is the water after the mixing valve. Trying to determine if it's a hot water fow issue or a heating issue.
If the red lines to the mixing valve are hot (and they should be pretty hot to the touch), then your mixing valve could be out of adjustment. If your hot water has worked before this outing, I would not see how your mixing valve would "come out of the adjustment" and now need adjusting. It may need tweaking, but no hot water at all is usually not a mixing valve issue.
Trying to walk down your system to determine if it's a water flow or alde heating issue.
Southern Maryland
North Georgia
If you have hot water to the mixing valve, it should heat your water fairly quickly. You may have to run a faucet a few minutes to get the hot water to travel from the mixing valve to your faucet.
Have you confirmed you have very hot water on the inlet side of the mixing valve? This is done by checking the red tubing going from the alde to the mixing valve.
Once you adjust the mixing valve, you can run your faucet for a minute and check the outet side of the mixing valve to confirm the water is hot.
If you do not have hot water either going to your mixing valve and to outlet side of the mixing valve there is something else going on.
Southern Maryland
North Georgia
When your sink faucet is in the hot position, are you getting cold water or no water flow in the hot position?
So when you flipped the yellow lever up, no water came out?
You are dry camping right?
Start at the water source and double check everything is hooked up right, your Nautalis is in the right configuration (the blue and green levers). The red level horizontal and not in bypass
Flip the yellow lever up and down just to make sure it is not stuck.
Your pump is working? You get cold water? Correct?
Sorry about the questions..but it helps to know the answers to get this going.
Southern Maryland
North Georgia
I am not convinced that your Alde tank is full. So, go ahead and open the yellow valve and put a bucket under it to measure the volume. Be careful as it may be very hot.
North Georgia
North Georgia
North Georgia
