To fill the Alde from the fresh water tank and pump, just open the hot tap and let it run via the pump until there is no sputtering of air. It is always best to do this maneuver hooked up to city water (no pump) as it is fast and then you don’t lose 2.5 gallons of water from your fresh tank.
To fill the Alde for hot water (assuming you are boondocking) , the yellow flap must be closed, the Nautilas is in dry camp mode, you have sufficent water in your on board tanks and your water pump must be on.
Questions:
So you had hot water at the sink for a minute or two but now no hot water?
You say the electrical plug was out. Why was it out? Could it be out again for some reason?
You say no heat at the red hose. I'm assuming you mean at the mixing valve inlet.
If you are still stuck and want to..I'll be happy to give you a call or you can call me (301-659-2898) and see if we can run this down. It may be easier than go back and forth in the forum.
Hi, Another way to help trouble shoot is to go to the Alde control panel. In the bottom right is tool symbol (looks like a gear). Click on that. Scroll to the 4 th screen until you see "Service" in the lower left. If you click on service, you can see the glycol and hot water tank temperatures.
Thanks Yoshi for the call, hot water! Not sure what all made the difference. But after draining the Aldi water tank I apparantly had my pump on and it filled the Alde tank. I guess that was going when right after I darained the Alde I could hear a noise and it seems that that was the pump filling the Alde tank. That service suggestion will help if you have problem as it gives you your currany glcol and hot water temp. Thanks all!!!
2022 T@B 320 S Boondock "UGA", Jeep Gladiator Overland North Georgia
The plug is for the Alde AC power so it can run on 120VAC Shore current, does not effect Alde whilst working on propane. The large black hose is the glycol circulation hose going to the cabin heating convectors, so Alde is heating. Are,the red water lines host?
Did you get any water draining out of the Alde when you flipped up ⬆️ the yellow valve? If not, you are not getting any water into the hot water tank. Try moving the Alde cutoff valve the other way round to vertical position, perhaps it got connected incorrectly?
The maximum hot water temperature for the Alde is 151F, with Glycol temp at 158F, per the Alde control panel service settings readout. The maximum temp recommended for domestic hot water is 140F, so the hot water mixing valve should be set at for hot water temp. of 130-140F. for best safe use.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
North Georgia
North Georgia
Questions:
R/Stuart
2021 TAB 320 BD
Southern Maryland
What temperatures do you see there?
2021 TAB 320 BD
Southern Maryland
North Georgia
