I’ve had my 2014 T@B 320 CS-S for 2 years and taking the plunge with some big upgrades in Oct!! I haven’t found experienced NuCamp service centers here in Colorado, so I decided to make my first pilgrimage to Sugarcreek!! Worked with Austin the service manager and we are set to 1) upgrade to the boondock axle, 2) install the Alde high altitude kit and refresh the Alde glycol, and 3) -drum roll please- join my grey & black sewer outlets!! Very excited and actually looking forward to the drive.
So… it is a long way and not planning to do this regularly. Any other mods or upgrades I should consider doing while I’m there? Especially for an older model? Thanks!
0 ·
The MaxxAir fan is quieter, uses less power and you can leave the vent open during rain and travel. As Slacker noted, if you are happy with the Fantastic Fan, a much cheaper option is to just add a vent cover. There are many vent cover discussions here on the forum.
I had Nucamp install a boondock platform snd box.-love it.
I didn’t realize you could change the axle. Why join grey and black water? What is the advantage?
You’ve probably already seen all the great detailed posts about DIY grey/black sewer mods. I was going to do it myself this summer then decided to have NuCamp do it for me. My back appreciates not having to crawl under my box anymore to hook up the grey dump!
I think the kit is basically an additional propane regulator on the hose to the Alde that is sized for altitude. They tucked it right up behind the axle so it’s protected.. Apparently it’ll work just fine at sea level as well. I haven’t had a chance to try it yet but am hopeful it’ll do the trick.
You’re lucky Sugarcreek is in-state for you!! I drove over 20 hours and 6 states each way!! Let me know if you have any questions about arranging service. Hope they can hook you up with the T@B of your dreams!
your pictures are great. Here’s wishing smooth adventures.
2020 TAB 320 S Boondock Lite
2019 Toyota 4 Runner
Puget Sound Country
Thanks.. Took the little devil to the Tacoma WA Apache shop this morning. After a minor shock, We went ahead with Alde flush and fluid upgade. $700.. The bearing lub, winterize, and check the frame rivet thang, Another $500. With all well, we told them to have the sales folk to give us an offer. Doubt we would sell without a good price. Really like, but cost of fuel, etc, could trade for a couple trips to Europe, or a lot of hotels.
Puget Sound Country
Not sure what the rest of the country is charging, but the last time I saw, a Pennsylvania dealer charged $285 for the exchange.
Here's what they include for that price:
Perform manufacturer recommended replacement of glycol. -Drain system, flush fresh water both directions using adapters and Suction Machine to vacuum the system.-Install drain plug fill with new Rhomar brand glycol at reservoir.-Set circulator pump to high to purge air from system and test for proper operation. -Adjust coolant level to "full Hot" and RESET pump to #2.( PRICE INDLUDES GLYCOL AND 2 HOURS OF LABOR plus $15 environmental fee to dispose of old glycol).
Miller Trailer Sales
If I may be so bold as to ask.
What were the costs on:
Grey water black water connect
Factory solar panel
The three diamond plate boxes on the front
High altitude adapter
Boondock axle conversion
Thanks
BTW Millers charges $315 now for the flush. Sounds reasonable compared to what some others have paid.
