As a prior owner of a 320 Tab with a three way I learned how temperamental the three way refrigerator can be. Through trial and error I learned to master it somewhat but do like the option when Boondocking.. The 400 Tabs are 2022 and wondering if the 12 volt system that runs off the battery will last for two to four days of off grid camping with frugal use of the electric. I have choice of either type of refrigeration system What do people think. thanks Bob
0 ·
Doug
Minnesota and Arizona
I ended up choosing the 3-way fridge for our 400 because at the time the only compressor fridge offered was the small one in the galley. At 6'2" I did not like having to crouch down and try to get stuff out of the fridge. The 3-way was larger and is much easier to organize and access. However now with the larger compressor fridge offered in the same location of the 3-way fridge I would opt for that if I were buying it now. While our 3-way has been flawless there are more things that can go wrong with them. Also the compressor fridges just get colder without a doubt and cool faster. And with the solar panel offered it should have no issues keeping your batteries charged and the fridge running. The only time I can see an issue is if you are without good sunlight for over 4 days.
2020 Toyota Tacoma Double Cab
Uses less 12VDC energy (a consideration when running off grid)
Has about a 1 CuFt larger capacity (new large 2-way is about 2-CuFt larger)
Fridge is mounted higher and access is more convenient.
Uses propane to cool, and needs venting to outside of trailer, vents can leak water, allow creatures in trailer, and look untidy. Getting propane mode to work can be challenging.
Uses more energy running on 12VDC than a 2-way compressor fridge.
Takes up the space previously occupied by wardrobe locker, on TaB400s built from 2019-2022. As of 2023 TaB400s, only a larger 2-way fridge is available.
Uses a compressor to create cold, does not use propane, or create heat from a flame burner to cool (does create some heat in the trailer, but not noticeable).
Seamless change from shore power to DC power.
Uses less power when running on 12VDC than 3-way fridge.
Better use of available space, as food storage area is larger over the same size absorption fridge.
On 2019-2022 TaB400’s, with the smaller 2-way fridge, you get a wardrobe locker for additional storage space.
Compressor does not run continuously, cycles off and on to reduce power use.
No exterior vents or penetrations through the trailer outer walls.
Less maintenance, no burners to clean, or propane lines to check for leaks.
Fridge food storage is smaller, and located under galley counter, so harder to access. Freezer compartment is smaller.
Uses 12 VDC whilst boondocking and requires 180-watts or more solar panels to maintain battery charge whilst camping off grid, so some sun shine is needed.
Compressor does make a slight humming sound whilst running. Compressor cycles off and on as required to cool fridge, so background noises are not constant white noise.
2019 Toyota Tacoma
Asheville, NC
"Don't postpone joy!"
2018 T@b 400
2019 Ram 1500 crew cab / 5.7 V8
We have no issue camping off grid with the AC/DC fridge, and normally get the single 200 watt AGM battery back up to full charge by mid-day. We do have two 100-watt portable panels I plan to connect to a second Victron 75/15, but have not needed to use them yet. The two 100-watt portable panels would also recover the battery, and offers more placement options to keep them in full sun.
I hope to see you at Colima in a few days and we can discuss this further.
2018 T@b 400
I have a 2019 400 and installed two Renogy 100W flexible panels and the Victron 75/15 controller. Routed the wires thru the roof next to the vent into the closet and then under the bed where I mounted the controller. Link below. Feel free to PM me with any questions.
https://tab-rv.vanillacommunity.com/discussion/13562/my-t-b-400-solar-install#latest
Poughquag, NY
