I'm paranoid and want to make sure I won't damage our camper when I go camping in a couple months (cold weather)
The water tanks will be empty, the water lines already have pink stuff in them (see my previous post,) and I'll be on shore power (30amp.) If I'm reading the manual for the Alde system right, once I get set up, make sure it's on electric, set to 2kW, and set the hot water bar to "none" and I should be ready to camp, yes? Set the temp to something comfortable, maybe crack the roof fan a smidge to get airflow, and relax?
Jay and Kat
Tow vehicle: 2022 Jeep Gladiator Sport S + tow package
Camper: 2022 T@B 400 Boondock w/Norcold 3-way fridge
0 ·
You need to crack open something when hanging out inside the camper for extended periods, lest you slowly smother yourself with CO2. If you don't have enough of an outdoor breeze to drive air exchange, you should probably run the fan too.
2022 T@b 320 S / 2021 Subaru Outback
Can I use my heating system even though the freshwater in my water heater has been drained off?
Yes, you can use your heating system as normal even if the water heater is empty.
https://www.alde.us/faq/
As you stated, make sure you turn off the hot water setting to "none" on the ALDE panel and you will be good to go.
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
Sold 2023 Tab 400
Sold 2018 T@B 320S
Or, would setting the window locks to the "second" position, not the fully closed, be enough to let some air in around the window without cooling things down too much? The ceiling vent would still be cracked open a smidge.
BTW, we've got a T@B 400
Jay and Kat
But I DO like the idea of a small fan like that anyways for the kitchen to blow out when we're cooking, if nothing else to try to move out some of the steam / etc from cooking. If you can, what's the brand and model of your fan? I'm presuming it's battery powered?
Jay and Kat
