Inside ceiling
What is the wood looking ceiling in a 2019 320 made of. It looks like real good but what is it? Thanks Art
2019 TaB 320 S Boondock Edge
  • db_cooperdb_cooper Member Posts: 740
    Pretty sure it's a birch veneer.  It has to be thin to bend the curve. It is  nice, adds an upscale look and resists smudges. Ours look like new after  4 years,  and I've bumped my head on it a lot. 🤕
  • MuttonChopsMuttonChops Member Posts: 1,863
    Good Questions - - - I will enjoy knowing the answer as well (just to know).
    I've assumed the ceiling is Veneer Birch Plywood, maybe even with Luan inter plys to keep weight down.
    Looking closely at it, I think its a printed laminate rather than actual wood veneer. It just doesn’t have the same look or feel as the cabinets.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,054
    This is from a 2017 thread where we discussed construction:  per Marvin at the factory:  the ceiling of the Tabs is actually a 1/8th inch ply with a veneer.   I believe a coated paper veneer.  Not wood - but it looks like wood.
  • ParlandoParlando Member Posts: 165
    We are getting some staining on the veneer next to the front window, probably due to condensation. Any suggestions on best product to coat the ceiling and those walls to help keep moisture from penetrating?
