Talk me off the ledge or push me over.
We bought two Vmax 125Ah AGM's about a year and a half ago. They still have lots of life in them, but now that lithium prices have dropped I'm thinking about switching. My contrived justification is that my basement staying dry relies on a sump pump. I'm thinking that the AGM's would be a good way to keep it running for a while if the power goes out. The other thing is weight. We're now at over 140 pounds (compared to 50 pounds for the lithium) of battery weight in our tongue box.
We recently purchased a Dr. Prepare 100Ah LiFePO4 to power a cooler in our TV. So far very happy with the quality and function. I can get two more for a little over $600 delivered. Any opinions on if it's time to take the plunge or is it better to wait for better prices and improved products?
1 ·
Which is why I haven’t personally made the switch, because I can’t justify it so far. But everyone’s needs and risk tolerance are different, and it may be a perfectly fine solution in your case.
The lack of heating that you (@VictoriaP) mention is less of a concern although maybe it should be. We have no plans to winter camp where the temperatures won't warm up enough to charge during the day, but that's still a risk to consider before making a decision. At least the low temperature cutoff should prevent damage.
If your able to move them inside, when the Alde heats up the cabin, they will be above 32 pretty quickly and can be charged. I don't know about all Li batteries, but most can be used/discharged in cold weather. Once they get above 32 (or there abouts), the BMS will allow charging.
You can also get temperature controlled heating pads that are not too expensive. Amazon.com: Facon 8-1/2'' x 5-1/2'' Silicone Battery Heater Pad with Thermostatically Controlled, Automotive Electric Silicone Battery Warmer Pad, 120V, 60Watts : Automotive
I was also on the fence for the same reasons, we don't camp in mid winter but do face a lot of <32 conditions as @Slackers points out for many of the places we go.
Good luck with your decision...
Southern Maryland
I purchased two of the refurbished Lion batteries. They were about 30% discounted. I'm in the process of installing them inside along with an inverter and transfer switch. I'm almost done. They only sell 100 Ah size. I felt ok with buying the refurbished ones because in my conversation with Lion, they said there was nothing actually wrong with them, but they are batteries that were taken to various trade shows and demos, and brought back to the factory for full testing. They may have been used and recharged. The ones I received were pristine with no marks on them. I believe they are still available along with a sale on the non refurbished ones. I've emailed Lion a bunch of times with questions about the BMS and other things. They were very quick with answers. They have a lot of info. on their website if your interested. Not just about their batteries, but about lithium battery technology in general. They are very light, about 23 lbs.
Southern Maryland
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
My sump pump is 3/4HP. I measured its draw at 700W and 6 amps while running. I'm looking for an inverter charger to keep the batteries topped off and switch to 12V if the power is interrupted. I emailed Renogy about this one. They say it will work, but looking for second opinion or to know if there are better options. Will I need anything in addition to the inverter charger for the pump to run on house power until there's an outage?
https://www.amazon.com/gp/product/B01MS9EI8Q/ref=ox_sc_act_title_1?smid=A2L77EE7U53NWQ&th=1
That said, for stability you always want to load heavier weight gear over the axle as much as possible, not at the extreme front or rear. Look for 10% to 15% of trailer weight on the hitch ball with the trailer level or slightly nose down.
On a dual axle trailer you want the trailer dead level to equalize the load on the axles and tires. On a single axle trailer such as our Tab, slight nose down is okay. Even better if the hitch weight is on the light side of 10% to 15%.
According to people in the hitch business I have met along the way over many years of towing single and dual axle trailers.
Minnesota and Arizona
