Reaching the roof at your campsite...
Jay_and_Kat
Member Posts: 301
Come this summer, we're going to be putting our moonshade up and a small TV antenna (magnetic) on the roof for some TV. We've got a small 2-step step stool which I am 99% certain is NOT going to get me high enough to put the suction cups on the roof.
I'm looking at possibly a 3-step step stool, but that might not get me as high as I'd like, which means my next option would be to pack along our 6ft step ladder, which seems to be a bit much. The final option, and this might not work on some campsites, would be to get the camper in place, then back the truck up next to the camper and stand in the bed.
So, if you attach things like awnings or such to the roof, what do you use?
Jay and Kat
Tow vehicle: 2022 Jeep Gladiator Sport S + tow package
Camper: 2022 T@B 400 Boondock w/Norcold 3-way fridge
Jay and Kat
I bought this ladder thinking I would need it for some reason:
https://www.amazon.com/gp/product/B002PNMMOC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
It is compact, but heavy. Something for your consideration.2016 Outback 320
Just weighted mine - 16 lbs.2016 Outback 320
Check out telescopic aluminum ladders.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
The telescopic ladders must be laid against the plastic roof trim. I thought the folding ladder would prevent any damage to the trim.2016 Outback 320
A 4' fiberglass stepladder should fit in the back of the Gladiator's 5' bed. Many items can be held in place by putting them between rungs in truck bed. I am 6' and combined with ladder's safe step height, can reach what's needed on T@B 400.
2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X Tucson, AZ0 -
Our challenge is getting stuff off the roof of our (slightly) lifted Wrangler. Currently using a two-step ladder picked up cheap at Harbor Freight. My wife always gives me a hard time for standing on the top handle that meant to carry it. I'm thinking that a 3-step might be enough.
Cheaper models out there, but I like this one.
FYI, you're probably going to be disappointed if you try to mount an antenna with a magnet without any additional mods. The roof is made of aluminum (not magnetic). You'd need to surface mount a magnetic plate first.Jay_and_Kat said:Come this summer, we're going to be putting our moonshade up and a small TV antenna (magnetic) on the roof for some TV.
Northern VA
2022 T@b 320 S / 2021 Subaru Outback2 -
I mounted this permately on the roof, works well! Did a post in this somewhere here! Art
2019 TaB 320 S Boondock Edge0 -
@techietab yeah, I knew that much.
I'm debating between either getting a small square of ferrous metal and some heavy duty tape (the sort of stuff automakers use to hold cars together in places,) for the antenna to attach to, or putting some velcro on the roof and the bottom of the antenna. McMaster-Carr has industrial-grade hook-and-loop with adhesive backing, including some intended for outdoor use that's UV and water resistant.
Downside is, I'd have to buy a 5ft long spool...
For now, I'm endeavoring to avoid putting holes in the camper.----------------------------------------------------------
Jay and Kat
Camper: 2022 T@B 400 Boondock w/Norcold 3-way fridge0 -
That is what I do, I have a folding 4- foot fiberglass stepladder that fits side to side in the Gladiator’s bed. This helps to organize the bed and keeps items packed in the bed, from sliding around. I also have a 2x6 that fits in notches on the rear sides of the bed, to add an additional divider.johnfconway said:A 4' fiberglass stepladder should fit in the back of the Gladiator's 5' bed. Many items can be held in place by putting them between rungs in truck bed. I am 6' and combined with ladder's safe step height, can reach what's needed on T@B 400.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.1 -
I’m not a fan of holes, either.Jay_and_Kat said:@techietab yeah, I knew that much.
For now, I'm endeavoring to avoid putting holes in the camper.I’m not familiar with whatever it is that McMaster-Carr has, but I’ve used 3M Dual Lock to attach all sorts of things to boats and trailers.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
