My experience with a dealer exchange back in October left the appearance of remaining Century fluid, but the dealer and nuCamp said it was not a problem. The dealer said that they did a distilled water flush before adding the new Rhomar, so there's no reason to believe otherwise.
For my own satisfaction, did a second exchange yesterday. I was going to use distilled water again, but on second thought decided it wasn't necessary. I wanted to avoid having to use extra Rhomar to push out the distilled water. With what was suppose to be a good Rhomar solution already in there, I would be doing a Rhomar to Rhomar exchange. Instead, I used a blowout method. After draining the system, I forced compressed air through the entire system at a fairly high volume.
From the results, it appears to have worked. In the top picture the left sample is fresh Rhomar and the right sample is what I pulled from the expansion tank after the dealer exchange. The bottom picture is a sample taken after my blowout method and running the system at a high temperature for several hours. It looks cloudier than the fresh sample, but I think that may be air bubbles trapped in suspension? The change in color is mainly what I was after.
I'm coming up on 2 years post finding my corrosion and cleaning it up. I double clamped all the connections and currently see no new bulges at all. I'm tempted to open it all up and put Miracle paint on the connectors, but I previously used JB weld on the worst areas, so I'm going to leave it be.
For our 2015 trailer I found @ScottG procedure of disconnecting at the low point near the boiler at the check valve and blowing air was enough to get a sufficient drain, and was easy enough to not deter me from doing frequent changes of the Century.
2022 Ford F350 Tremor | 2022 Cirrus 620
There is no way to get every drop of Century out unless you completely take the system apart clean and dry it then reassemble it. However if flushed very well with water prior to putting in Rhomar it is possible to get just about all of it out. Honestly when I completed my flush and refill I could not tell the difference between the bottled Rhomar and what was in my system. I would not do the switch because you feel you can't get enough of the Century out. You can with a good solid water flush and proper bleeding as it is being filled with Rhomar. Took my about 3 hours with some learning allow the way. I could probably do it in 2 now if I had to do it again.
2020 Tacoma TRD Off-Road
https://tab-rv.vanillacommunity.com/discussion/13409/switching-to-new-rhomar-glycol/p5
The picture below is from after they system sat overnight. On the left is the new sample from my expansion tank. The right is fresh Rhomar. It did clear out and now looks more similar to your results.
Your writeup on the process is awesome. Thank you for taking the time to put this together.
Disclaimer: The color, clarity, pH & specific gravity of "normal" urine can vary widely, but your glycol "before & after" change should not.
2022 - 11 trips - 34 nights
2023 - 4 trips - 21 nights
2024 - 5 trips - 51 nights
2025 - 5 trips - 18 nights
2024 Ford Ranger Raptor (10.5 mpg towing avg)
2018 BMW X5 xDrive35diesel (15.6 mpg towing avg)
2020 Toyota Tacoma TRD Off Road (11.1 mpg towing avg)
You have the Rhomar glycol in yours. They changed to Rhomar at the beginning of 2021 (it might be late December 2020 builds but I'm not sure).
Century fluid is fluorescent yellow and Rhomar is Blue-ish green.
managed by VE Smart Network
