I have to replace my entire outside shower unit (broken part) and have one on order from NuCamp via my dealer. It’s really a “plug and play” unit and I dislike paying for service if I can do it myself. I also don’t want to damage the Azdel by doing it myself. I would imagine that there needs to be some sort of sealant involved. Has anyone here done this, and how did it go? Thanks!
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
0 ·
It's easy to replace. Just gently scrap off the old sealant with a putty knife, unscrew the old unit, move the hoses to new unit and re-install and reseal. Make sure the pump is off before starting.
https://www.amazon.com/Camco-43716-Marine-Flexible-Replacement/dp/B000NOSSEI/ref=sr_1_5?keywords=rv+shower+hose&qid=1677169505&sprefix=rv+shower+hose%2Caps%2C295&sr=8-5
Also as @Horigan notes above attach the hoses to the new box before tightening down the screws and sealing with caulk.
https://tab-rv.vanillacommunity.com/discussion/16114/quick-disconnect-for-the-outdoor-shower-a-success#latest
The link above at a minumum will give you a good idea on what's involved to remove and replace the shower box. Just four screws once the sealant is removed.
"Just Enough"
