With full hookups should I leave the black tank drain closed until it’s close to full so that the enzyme treatment can work? It seems that if it’s left open “stuff” will just sit there until there’s enough liquid to help it drain.
Never leave the black tank valve open while hooked up. That’s how you end up with the dreaded poop pyramid directly beneath the toilet. Open that valve only when you’ve got a decent mix of liquids with your solids, preferably around 2/3 full, and when you have plenty of water to flush the tank out after dumping.
You do NOT want to deal with the mess that can occur from not having enough liquid to push things along. Anyone who’s dealt with a poorly maintained black tank in a used RV can attest.
2019 320s BD Lite, white with blue (“Haven”) 2015 Subaru Outback 3.6r (unsafe 200lb tongue weight limit until 2020 models) 2020 Subaru Outback XT Pacific NW
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
