Hi all,
I see I can now start a "discussion" so I thought I would make my first post on this forum. First let me say "hi all" from south western Colorado.
I am new to the Nu-Camp world but not a first time RV'r. I recently brought home a 2017 T@B 320 Outback. It is in our driveway where I am going thru things trying to get it road and camp ready.
It has a couple 12Volt deep cycle batteries in the box with the propane tank. Looked like the batteries had some acid on top of them and at some point some of the acid made its way to the metal bottom of the box. I took everything out and cleaned it all with soda and a little water. Nothing had been damaged by the batteries but the short red wire between the batteries needs new ends.
I did not get a jack with the trailer. I have a large scissor lift jack that I have modified to work on it. It took me an hour or so to come up with a solid jack to trailer connection. Nothing fancy, just a little U-shaped bracket attached to the top of the jack to capture that L-shaped metal part sticking down. I feel like now I can take the wheels off one at a time and start to work on inspecting and repacking the wheel bearings. The scissor jack has a 3/4" head on the screw so I plan on just putting a socket on my cordless drill to run the jack up and down.
The tires were a little low on pressure so I put them all to 45. The spare was on the rack on the back. I took it off and ordered a bracket so that I can mount it on the tongue just behind the screw jack. I can handle the spare a lot easier if it was on the tongue rather than having to lift it down from that rack or put it back up there. My tow unit is a Ford F150 so I am not too concerned about what the tire weight will add to tongue weight. I'm just hoping that I can find a good weight distribution in the whole of the trailer. It has a weight distribution hitch that came with it. I may use it if it helps with sway.
Once I get the running gear all serviced, I think I will start studying out the water system and the Aldi. I ordered a wand for cleaning the black water holding tank.
The trailer is solar ready which is nice. At some point I think I will get a panel that I can just sit on the ground next to the trailer.
The refrigerator is a 3-way. Hope it will work well on gas.
I'm buying a portable generator to use with the trailer. Something with at least 1600 watt capability. I want to be able to use a little portable heater on occasion that is about a 1200 watt load. There is an A/C unit but I will most likely never run it. Might take it out. Just don't know what I would use to block off the opening in the side of trailer
That's where I'm at on getting this unit going again. I have been mining this forum for a lot of info to help me figure this little trailer out. Lots of good stuff on here. Thanks to all for sharing your experiences and knowledge.
Happy camping,
Mike in CO
1 ·
You might want to check the condition of the batteries. Often times when they have corrosion they have taken some abuse. You don't need a weight distributing hitch with a full size truck as tow vehicle so you can save yourself some hassle there. The Alde system (not Aldi, that's a grocery chain ) is really nice for heating but has the drawback that it takes a while to heat the trailer. If you want instant heat the portable heater will do the trick, but try the Alde and maybe there is even less stuff to carry around. I'm old school (not to say old) and I like the gas fridge but it is a little finicky. There is no thermostat when running on gas (or 12V for that matter) so you need to adjust the temperature during the day. If you leave it on a higher setting overnight it can freeze your food. The knob directly adjusts the flame size which is different from most other RV fridges that use an electric control board and turn the flame on and off as needed. The absorption process has a limit of about 95F air temperature so it is important to keep airflow going in the trailer and across the condenser. Many owners add another fan to the fridge vent to keep air moving.
That's all the things I learned coming from a larger travel trailer.
Enjoy !
Going on the info you provided, I will be putting a thermometer in the fridge and run it for a couple days to see what I can do to regulate the temp. Good info, thanks again.
Yes, Alde, sorry. Kind of wish it was mothballed entirely. I am planning to heat water outside on a stove, and do all washing up outside. Really only want water at the toilet.
Not sure if the 2017 came with the built in valves to bypass the water heater (Alde); if so, you can always just leave it in bypass mode if you don’t want to use it.
Thanks again for the welcome. Looks like some knowledgeable people on the forum.
https://tab-rv.vanillacommunity.com/discussion/comment/188151/#Comment_188151
No damage to trailer or rim, though we were lucky to find a place very quickly to pull off the road. And it was not a busy road, out in the country in SW Virginia, 55mph.
I didn't want to have one more item to store in my tab. With every trailer that I own, I either match or change the lug nuts ($14.00) to match the ones on my toe vehicle. That way the jack and wrenches of the vehicle will serve to service the trailer.
We have a 2018 CS. The Alde is great, but it does take an hour or two to come up to temperature. Once it gets warm, you won't want any other kind of heater.
We have found most of the jumping bean dance while towing is a caused by the undercut front of the trailer. If you put boxes or even a flat plate to prevent air from going under the trailer, all that bounce and wiggle stops.
"Just Enough"
Thank you for that information Mickerly. I was planning to get boxes to mount on the sides of the tank/battery box. Probably just some cheapy plastic ones but something. Good to know they will serve to help with the tow. Thanks again.
