For those who have a 2-way refrigerator in your T@B, particularly those who have replaced their original 3-way model, what has been your experience as far as the refrigerator staying cold when the ambient/outside temperature is in the 90's, or low 100's?
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
0 ·
What really makes a difference is the interior temps. If you can get the interior cool using the AC then the fridge works great. I’ve seen some people add additional fans behind the fridge to help move the hot air out from behind it. But if the interior of the camper is hot then it doesn’t do much good.
2020 Tacoma TRD Off-Road
"Just Enough"
The nüCamp provided smaller 2-way fridges in this discussion are 12VDC only units, with a smaller compressor, that is more efficient than your larger unit whilst running on 12VDC.
An interesting experiment would be to see if you can set the fridge to 24VDC and power it with two 12 volt batteries to see if it works better?
Thinking to buy a portable 12V fridge to carry in 4Runner which I have put Solar panels on top to charge a Kodiak solar generator I carry there. Any suggestions?
https://icecofreezer.com/products/iceco-vl45-portable-refrigerator-freezer
Most replacements on the T@b302's utilize the extra space when switching to a 2 way refrigerator for additional storage, but I am looking at using it to duct outside air in an out through the original side vents in hot weather and then being able to easily switch it to venting inside in cold weather to capture the heat inside.
Just in the "design" phase but looks very doable.
As you have probably already seen from reviewing posts regarding installing the Isotherm Cruise 65 Elegance two-way, I chose it to replace my Isotherm. So far, it has worked great. Much better than the Norcold N180.3 and it is really nice to have the freezer compartment.
Initially, I left the side vents open to get plenty of fresh air to the refrigerator. However, I have since blocked off those vents, because too much cold air was entering the trailer cabin. We took a three-month trip last fall (approx. 20,000 miles), before I closed off the vents, and we had a lot of cold air entering the trailer cabin via those vents. Air primarily flowed in and under the refrigerator, which is raised about an inch above the cabinet base as required for proper operation.
I suppose that installing some sort of ducting to the side vent(s) might be configured, but it will likely be difficult. There will not be much space to run ducting, because the refrigerator body is a perfect fit and the compressor/fan are located at the top rear of the refrigerator. There is space on the side of the refrigerator that is adjacent to the external vents of the trailer, but how to direct air (fresh or exhaust) from/to those vent(s) may be challenging.
This past March, after closing off the vents, we took a 4,000 mile trip between Arizona and Ohio (nuCamp) and had no issues. The weather was primarily cold, but we didn't have cold air blowing in through the outside vents. I did also modify my installation of the refrigerator to allow the refrigerator compartment to have better air circulation (by adding a few round exhaust vents above the refrigerator), but it is the same as you and @AZGal have described (i.e., the refrigerator both brings in fresh air and vents hotter exhaust air from inside the trailer cabin - - no external venting.) I do keep the roof vent open partially, or fully, plus I at least crack open one or two windows to promote better air circulation within the trailer interior.
We will be taking another three month trip later this summer and will be in both hot and cool/cold regions of the U.S./Canada, so that should be a good test of how I currently have everything configured.
By the way, this is also the source of cold in the winter causing our condensation problems.
"Just Enough"
Here are a couple sketches showing the concept:
Above shows upper and lower existing vents with existing vertical board which I will leave in with a hole cut in the lower portion as shown below.
Above sketch shows new plywood (in blue) to isolate upper and lower hot and cold air with a new small storage area in between. In the above sketch you can envision venting the refrigerator from the interior of the trailer or from outside. The yellow is the existing framing of the front counter. This would allow conservation of heat in cold weather to heat the interior and in cold weather not to heat the trailer interior with simple blocking the vents inside the trailer above and below the storage area and installing removable vent covers on the existing vents in the trailer wall (hope this makes sense).
What's not shown is the baffling to isolate the cold air across the top of the refrigerator and compressor and hot air after the condenser fan to force the hot air down between the outer front shell of the rv and the back of the refrigerator to the hole cut in the bottom of the existing insulated board left in from the old refrigerator that most people remove. By pulling cold are in the upper vent also reduces the dust pulled into the trailer when on dirt roads, hopefully anyway.
As you are likely already aware, my Isotherm (and the nuCamp installations, I believe) has the refrigerator propped up on a couple risers/runners below the feet on each side so fresh air can enter below the lower front of the refrigerator.
(1) Should your air flow be reversed, with cool air entering from the bottom and hot air venting out the top? Hot air rises, so that seems necessary.
(2) IF you do have to raise the refrigerator in a similar manner, the right side runner (closest to the side vents) will likely block most of the air flow under the refrigerator. (You might be able to install the runners in a side-to-side orientation, rather than front-to-back, but it might make installation of the refrigerator a bit more difficult, but not necessarily impossible.)
Here's a photo of the runners I am referring to. Hopefully, what I have described makes some sense. Also, just for your info, the top of the Isotherm just barely slides under the stove's propane regulator depicted in the photo, so be sure to factor that into your planning.
It looks like you are on the right track. I am looking forward to seeing how it all turns out.
I realize I am trying to force hot air to go down to exit. I could reverse it but if I can, I would like to pull air in the upper vent to reduce dust pulled in when on unimproved roads. If needed I could add an additional fan in the cut opening in the existing support to the countertop. I'm counting on the fan or fans (if additional fan is needed) to force the air down. But even after installation, I could reverse the air flow.
Since I don't have to raise the unit up on runners, it will clear the stove regulator since it's no taller than the Isotherm unit so I should have about 1" clearance.
The dimensions I'm waiting for are the compressor/condenser overhang on the back side and details on the triangular bottom corner of the box to verify clearance with the trailer front wall.
The unanswered question is the effective openings to ensure sufficient airflow since it's not simply an outlet to a vent on each side of the unit. I need to get my mind around that issue, but worst case that can be solved with and additional fan to aid the one on the condenser.
I ordered the Vitrifrigo. Although the web site said they had 5 in stock, they didn't and shipment isn't expected until end of this coming week.
I'm confident I can arrange the cooling air and hot air exhaust from either the interior of the trailer in cold weather to help heat the interior or from the outside via the existing side vents when desired or needed. Will update once I get to work with the unit after receiving it.
"Just Enough"
Norcold 180.3 Out and Vitrifrigo C62IXD4-F In"
The idea with the vents is to create a convective flow of air, which should help at least a little.
2018 T@B 320CS-S
2022 Toyota 4Runner
