I have a 2018 T@B 320 Outback that I'm going to add the Lagun table
mount to the outside of the trailer. I plan to put it next to the
horizontal 120V outlets behind the wheel well.
I
have the bracket and ordered/received the plastic spacer block from nuCamp. How have others supported the bracket on the inside of the trailer? I have seen a
picture where someone put the board that came with the bracket kit
against the inside of the azdel panel under the rear seat. I'm
concerned that mounting that way puts most of the load on the inside and
outside panels of the azdel foam sandwich. I was thinking about adding
plywood (glue/screw) that sits on the interior plywood panel under the
seat so that the load will rest on the trailer floor.
It would be helpful if someone could post a picture of how the factory
installed bracket is supported on the inside of the trailer under the
seat on the newer models.
https://tab-rv.vanillacommunity.com/discussion/comment/86297#Comment_86297
please and thanks
Tom
I'll see if I can find the invoice. Had it installed at NuCamp
You will most likely need longer bolts to go through the outside wall and back plate than come with the kit.
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
