Hi all, when I first got my 2004 T@B T2 home, I plugged in and checked all the lights and outlets inside the trailer and everything worked fine. After connecting a battery and getting the cook top and fridge to work, I planned to spend the night in it in my yard just see how quiet, warm and comfortable it will be when camping. I went to plug in my phone to recharge and I discovered that none of the outlets were working. I've gone through all of the manuals and googled but have come up with nothing. The 2 outlets in the trailer are not have GFCI outlets. AC power was on to the trailer. Any suggestions?
0 ·
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
You need to have the trailer connected to 120vac (shore power) for any of this to work. When running off the battery, the power center provides fuses for the many 12v circuits. Have you checked the circuit breaker in the converter?
I think it is time to follow the voltage with a meter. Something is missing or not working suddenly.
All the lights in the trailer run off 12V battery power so that does not mean anything for the 120V AC side.
In the other thread you wrote that initially you had no battery but the trailer plugged in and the interior lights worked. Disconnect the battery and see if this is still true. This will tell us if there is 120V AC coming to the converter.
For @Pattie57
1) Are you 100% certain the House outlet is live.
You have tested it with a plug-in fan/light/whatever.
2) Super search the trailer interior and exterior for a GFCI outlet.
The Dutchman Documents say the TaBs had one.
It could be hiding under a shelf/cabinet or even under the benches.
And of course could be outside.
For all the Folks Trying to Solve the problem
3) Attached file (.jpg) has a basic Dutchman Electrical Wiring Overview from yr-2005
Good hunting, everyone.
If the lights etc don't work without the battery even though the trailer is plugged in it very likely is a problem outside the trailer. To reiterate @MuttonChops point: If you plug something else into the house outlet where the trailer is connected, does the light or whatever work ? Also make sure the cable is securely attached at the trailer side.
