Well after reading about every comment on the outdoor shower (I have the Fontana box on my 400), I knew I needed an upgrade as the back side connections would leak despite all I tried. And this time I found out why. Here is my removal and upgrade thanks to
@DenisP for the one I chose but it is similar to others.
First, what is wrong with the pull out hose and sprayer on the Fontana? Just about everything.
Once you remove the 4 screws and the caulk (which I had done last year due to a leak at the mix valve in center, I found the same connection had loosened again and this time saw why. Each pull in and out of the hose was applying some twist to the connector and it was unscrewing itself. Others have found with enough pull it will kink and also leak. It stopped when I tightened it but this time I was over it and had the quick disconnect ready to install.
I got the RecPro used by
@DenisP
The spray port cowling easily unscrews from the metal quick disconnect, which is quite sturdy. The PVC rear filling is standard 1/2 inch and has a backflow valve in it that can fall out. This is where I had to ask
@DenisP how he secured the disconnect in the box. It was pretty easy. The cowling has a hex head size taper that secures the metal quick disconnect. I used a small hacksaw and carefully cut the cowling. It worked with no problems.
So now it was just using a hole saw to cut the hole just slightly larger than the metal threads, and wrap with plumbers tape to get the PVC to snug to the fitting and also tighten on the box. The plastic hex washer I had cut off was needed as a hold point to keep the quick disconnect from turning while I tightened the PVC fitting. It worked.
The braided connection between the mix outlet and the fitting is a standard 1/2 inch supply line fitting and does not interfere on re assembly
So the supply lines are hand tight fittings and when I reconnected to the trailer I had to tighten the braided line once more at the mix valve and all was good.
The pressure and flow from the quick disconnect is multiple times more than I was ever able to get before, and I can use any sprayer I want since it is a standard hose fitting on the coiled hose.
Bottom line this was NOT that hard and NOT very expensive to upgrade with basic tools and is WAY better function not counting the piece of mind of NOT damaging the trailer with leaking behind the wall.
I'll seal it back up after the leak test and thanks to all for the ideas!
QH
2013 Tundra TRD 5.7L
Massachusetts
Trips - 48 Mileage - 63,452
These next pictures are the hoses with blue stripe that come from black tank flush on our 2019 and travel up to check valve and then back down to black tank. When I did the folding sink take out I noted gaps and used some brass wool to provide a barrier. But so far that has worked just fine.
The second shot is the now disconnected 3/4 corrugated drain from our old round folding sink that I could see would pretty easily clog. Others have replumbed this to standard fittings with sink upgrades in the shower with good success I think.
Massachusetts
I'm doing the same mod. but seem to be having an issue with water flow when I connect the new braided hose to the center water inlet shown at the black arrow. The new braided connector (and all I can find) has a small brass fitting (third photo) that interferes with the OEM center inlet (second photo). Did you anyone have a similar issue or am I doing something wrong. Thank you
Southern Maryland
An alternative is to use AnOldUR technique - cut the original hose and use a barb connection https://tab-rv.vanillacommunity.com/discussion/17067/outdoor-shower-quick-connect-issue#latest I did not want to destroy the original hose.
2020 V6 Chevy Colorado
tks for the responce...it was driving me nuts what was going on. I looked but did not see your post. I was measuring the openings looking for differences in size, etc. I finally noticed when I backed off the hose coupling water began to flow. I ended up using something similar.
Southern Maryland
