It appears that the WFCO-8735/40 converter in my 320BD is not charging the battery at all.
The background is this: Last week, I fully charged the LiFePO4 battery via an external charger (Victron BSC), checking the voltage afterward, so am certain I started with a fully charged battery. The camper has been plugged in to shore power since then, but the battery has lost charge every day, and this morning read 13.06 volts. The relevant fuses at the converter (5 & 6) seem to be good (pulled, checked visually and with the VOM) and the camper has AC power throughout. I've since turned off the battery switch and reconnected the external charger.
Could it be the case that the WFCO is not providing current to charge the battery but is otherwise working OK? I know that this model will not fully charge a lithium battery but it should still keep it charged to some extent.
Sounds like your converter may be taking a turn for the worse. At 13.06, I would have thought it would start to charge, in looking at the the specs the Float Voltage is 13.2 V which is likely the same thing that I have experienced a couple of times.
***EDIT*** It is possible that at 13.06 Volts that the converter doesn't deem it necessary to charge, since it is not that far off of the Float Voltage. The fact that the battery has "lost voltage every day" doesn't shock me since it is not meant for Lithium Batteries, Lithium Batteries have quite a bit higher voltage from fully charged to completely discharged.
If you were to add a load to the 12 volt side, does the voltage continue to drop or does it recover? IE turn the ceiling fan on High to add a load and watch the voltage to see if it starts to come up.
The other thing that can affect this is the gauge of wiring from the power distribution center to the battery and the distance. That was one of the major issues with our 400 until I installed a converter close to the batteries. The resistance over the distance prevented the Bulk Charging Mode from ever being used. On your 320, I have no idea as to the distance or location of the Power Center (Converter) to the battery.
Brad
Concord, NC
Are your battery voltage readings taken at the battery terminals?
Do you have a voltmeter in the camper? If so, what is it registering when plugged into shore power?
Mine usually reads ~13.65V. If you are getting that in the camper but something significantly lower at the battery, that suggests the converter is fine but the connection to the battery is compromised.
Whether or not that converter is suitable for charging your lithium battery is another issue about which I have no expertise.
+ Do your 12V Outlet voltage check with battery cut-off switch in both positions. Battery 'load' or circuit could be dropping the voltage . . . ie. Convertor output normal with battery out-of-circuit
+ If you don't get the typical 13.6VDC with battery out-of-circuit. Try removing DC Panel fuses one-at-a-time to isolate some other T@B DC Circuit issue before deciding the convertor is the issue.
Adventures: 58 Nights: 405 Towing Miles 50,180
I suspect that if you were to draw the BB down to a lower voltage that you would see the converter charge at the absorption rate.
***EDIT*** The voltage level being higher on Lithium is why the standard converter will not fully charge them, it senses the voltage being in the upper range and typically will not charge at the Bulk Rate or goes into the Absorption Rate too soon. With my converter, I can force the Bulk Rate via the Boost Mode (which is 14.4 volts) and easily get 100% SOC.
Brad
Concord, NC
